Sponsored by:
Sponsored by: CARiD
Closed/Open intake VS Water
Old Jul 19, 2012 | 11:03 AM
hackerrei's Avatar
Hi all.
Ok so we all know intakes look and sound great but are only needed if upgrading the turbo needing a bigger MAF housing so no question there.
But what is the question is 80% of all EVO X intakes place the filter at the snorkel which is also near or under the driver side hood vent.
So now here it come with a open elem filter system would or could water get in or on the filter when driving in the rain or through a car wash?
Closed elem filter systems should be a little safer in this fact. how many people took the metal plates off the bottom of the plastic vent to let more air out the bay?
Bonus Question
Who took the alumin shield off the hood scoop or just cut the back out to open it to let more air into the bay? Was there any problem there also when raining like water getting on the hot turbo?
Old Jul 19, 2012 | 11:07 AM
Kracka's Avatar
AFE Stage 2 DryflowS intake here and zero issues in hard rain, car washes, etc.
I cut open the metal ducting on the hood scoop it allow more airflow over the manifold & turbo; again, no issues. My opening in the metal is the same size as the scoop now.
Old Jul 19, 2012 | 11:09 AM
gsrboi80's Avatar
As long as you don't submerge the filter element in water ie. Drive threw a pond, you wont have any issues
Old Jul 21, 2012 | 05:35 PM
hackerrei's Avatar
Well today I took off the heat shield under the hood scoop and will later put black chicken wire across it. I think since my 8 I took off the shield under the hood vent which was over the turbo like most older evo drivers do i had no problems with driving in the rain or running the car a while then going trough a car wash the x should be ok. My biggest worry was pushing the car then having water fall on the turbo or manifold causing damage. Any one else take the whole aluminum piece under the scoop and not just cut it bigger?
Old Jul 23, 2012 | 07:11 AM
hackerrei's Avatar
Yesterday it rained pretty good and every thing seems good. After the rain I dried off the hood and scoop then opened to see where the water fell. There was a little water on the engine cover and the manifold heat shied but not enough to pool. Manifold was dry and turbo was a little wet from spray most the water hit the fire wall and ran down behinde the turbo. I will be getting the chicken wire on the 1st after I install I will post pics. I would take off both plastic vents and just use the CW but I think it will look ugly so I am leaving them in.
Next item
Has any one cut out or ordered a front bumper like pictured below and if running stock or after market box intakes would this suck up water into the filter really bad?
Because this might be the next body mod for me just need to finde some one that could fab it for me out of my stock bumper.
Attached Thumbnails Closed/Open intake VS Water-front-bumper-sport-mitsubishi-lancer-evolution-x-fq-400.jpg
Old Jul 23, 2012 | 07:26 AM
jdmEviL8's Avatar
^ let us know where and how much u paid to get the fq400 front bumper :P
Old Jul 23, 2012 | 08:18 AM
hackerrei's Avatar
Well really I want to fab it into my stock bumper at a body shop have them cut it out smooth it then repaint the area. Then install from japanparts.com super suction kit which gives you a bigger snorkle then I will have them make the hole the same size as the new snorkle that way it could suck in even more air then stock. Here is pic and part number is 3PSP21 price is 73,000 yen
Attached Thumbnails Closed/Open intake VS Water-imagefromdbcatbly2j.jpg
Old Jul 23, 2012 | 09:48 AM
jdmEviL8's Avatar
what about cold air intake?
Old Jul 23, 2012 | 10:52 AM
hackerrei's Avatar
I think it should work with box intakes like ARC and AEM. As for every thing else like open elim intakes it will be the same as the stock snorkle just able to collect more air.
But the water question is if a shop cut out the bumper and hood to meet the opening of the snorkle making the intake true ram air would it collect enough water from driving to damage the filter or go through it and damage the turbo/engine or would the couple of drop that do make it into the snorkle not be that affective to damage any thing.
Has any one seen or tried this setup?
Old Sep 2, 2012 | 08:37 PM
evo warrant's Avatar
Never had a problem with my EVO or my STi, even in WA.
Old Sep 2, 2012 | 09:11 PM
genelee112601's Avatar
Current with AMS Cold Air with MR Foglight Grill no Problem at all...
Randal
12
May 23, 2024 11:01 AM
iLLevo_
Sep 6, 2016 09:32 AM
TigOLDBiTTies
Jul 19, 2015 11:30 PM
R. Burgundy
Aug 15, 2012 09:35 PM
Cesarn2928
18
Nov 2, 2011 01:46 PM
