Sponsored by:
Sponsored by: CARiD
Transfer case and gearbox oil location
Old Oct 24, 2012 | 09:49 AM
adrianTNT's Avatar
Question Transfer case and gearbox oil location
A while ago my Evo X had a leak between transfer case and gearbox.
We just replaced on the transfer case one seal and a larger oring that was next to that seal. We stopped the leaks but I am not sure if there were more seals that needed replacement.
- After draining the transfer box oil, we took it apart from the gearbox and oil started to drain between them (gearbox oil I assume), it was a lot so we then drained the gearbox too. Are we supposed to have gearbox oil there (between tcase and gearbox) ?
- Anyone knows if there is a seal on the gearbox like in attached image ?
Maybe someone took the gearbox off and knows if it is supposed to keep its oil inside or leak on the side with transfer case.
An image with details is attached.
Attached Thumbnails Transfer case and gearbox oil location-evo-x-transfer-case-gearbox.jpg
PIGG1E
11
Mar 24, 2018 02:56 AM
mateusz
May 18, 2014 09:58 AM
EvoIIIAj
Sep 30, 2011 04:25 PM
FALCO
21
Feb 15, 2011 08:18 PM
maciekish
Apr 18, 2007 08:05 AM
