Found a good floor jack adapter
I found it frustrating not being able to jack the car up on the side. I got one of these adapters (no affiliation) http://www.mrtool.com/browse.cfm/flo...er/4,1359.html
and it fits the frame great. I can now easily jack the car up on the side.
Why not just lift it from the usual point used with a lift. Thats hard to word without being confusing. The rail that runs under the car about a foot in doesnt bucket under the weight... Neither does the plate behind the fron tires that has the 3 holes stamped into it. Or the rear suspension arm mount
Yup, if using a scissor jack that fits perfectly into the notches. But if you use a typical floor jack on the seam weld, you risk folding it over.
For the front, the ideal location is under the splash panels, on the frame. This method gets both front tires up at once. (Be sure to block the rear tires.) It's a bit of a pain, especially if your car is lowered. It means driving up on ramps in order to unclip the panels. This pic shows it best.
(source of pic from: https://www.evolutionm.net/forums/ev...-included.html)
To lift the rear up, use the diff. Circled spot is where you put the jack.
I also use this spot. You may need to drive onto a pc of 2x10 to get access to it, depending on how low your car is, or you jack height.
Always put something thin but strong between the jack and your car to help distribute the weight evenly. Such as a piece of hardwood flooring.
+1 on this:
and this:
The suggestion that you can't or shouldn't do this because it isn't what that manual says is amusing when coming from someone who has a picture of his or her Evo autocrossing as his or her avatar. That, too, is disallowed by the manual.
The only issue for me was how to lift the car when I'm putting it on jack-stands. The rear is easy: lift by the diff. The front is harder, because my favorite lift-points (see above) are the same as the best places for the jack-stands. That was solved by the skid-plate.
and this:
xwxspawnxwx
19
Jul 17, 2011 10:40 AM
Srt-4 Turbo 7
May 8, 2010 01:08 PM
song-b
04-06 Lancer Ralliart How To Requests / Questions / Tips
12
Mar 9, 2009 03:44 PM
