Sponsored by:
Sponsored by: CARiD
Evo X Side Jacking Point
Old May 26, 2011 | 10:12 PM
lpy2009's Avatar
As topic, is it alright if i jack the car up on the side through the chassis rail ? Further down the stock jacking point stated in the manual.
This is with a trolley jack
Highlighted in Red
Old May 26, 2011 | 11:38 PM
Segfault's Avatar
I do it all the time when changing wheels at auto-x :-p Just be careful you're not on the plastic lip of the side skirt. You can also use the frame too. If you need just the back of the car, use the diff as jack point.
Old May 27, 2011 | 06:08 AM
Kracka's Avatar
I use a floor jack + hockey puck (thanks SiliconTek) and it works perfectly, my rails still look brand new. Works great on the rear diff too.
Old May 27, 2011 | 06:19 AM
comic0guy's Avatar
this topic always pops up every now and then....
I've used the frame rails and worked fine, probably best to have something like rubber to take spread the impact out.
Also, anyone think using the subframe rails(the 3 inch wide rail just inside the frame rail that is coated) is a good idea? I've thought about trying that next time since its nice and wide.
Old May 27, 2011 | 09:24 AM
derekste's Avatar
I would not use the frame rail or subframe rail. A friend bent the frame of a *Miata* doing that.
Jacking the car up on the sides is such a PITA anyways esp. if you are trying to put jackstands under it that I don't know why you would never use the suggest front and rear points.
Old May 27, 2011 | 09:58 AM
linjy2's Avatar
I use the side because my jack cant fit in through the front. car is too low.
Old May 27, 2011 | 10:26 AM
macPSU's Avatar
Same here.
Old May 27, 2011 | 11:19 AM
No_Skillz's Avatar
Harbor freight. 3000 lb aluminum race jack for $69!
Old Feb 11, 2012 | 08:22 PM
importunerdj's Avatar
Sorry a little panicked, the rail bent a bit, does that damage anything on my car? its just a small bit bent (on that thin rail).
Old Feb 13, 2012 | 06:31 AM
EvoStig's Avatar
No, I wouldn't worry about a little bend.
Old Feb 13, 2012 | 10:50 AM
deludedbuzz's Avatar
I don't use the front because you have to remove the freaking underpanel to get to the front jack point.
Old Feb 13, 2012 | 11:39 AM
Optiblue's Avatar
+1 This also my technique!
Old Feb 14, 2012 | 11:15 AM
EVOSEX's Avatar
my roomate has one and its nice but after 3years or usage its leaking oil..
I got mine from American Steel industry Jack for like $ 219 and Its buff and heavy but heavy duty and lowcar friendly~
Old Feb 17, 2012 | 08:39 AM
Johnr352's Avatar
Oh goodness, changing wheels 3 times per day at the track and you should see my rails. We jack at about mid point on the front door, maybe a little closer to the front, and lift them whole side to do two wheels at a time. Works fine.
Old Oct 12, 2014 | 05:58 PM
gvvg13's Avatar
good info
McRooster
May 7, 2017 11:07 AM
EvoCop
Nov 4, 2016 05:37 PM
drivejumpfly
Mar 21, 2016 12:16 PM
song-b
04-06 Lancer Ralliart How To Requests / Questions / Tips
12
Mar 9, 2009 03:44 PM
shawnhayes
Aug 26, 2003 01:47 PM
