Sponsored by:
Sponsored by: CARiD
Fuel Pump / Pumps for 550whp +
Old Jan 2, 2013 | 10:29 AM
5LEEPERISAH23I's Avatar
Im writing this thread on behalf a good friend. He is building a MAP 2.0L he is going the transformation from 93 pump to E85. Right now he has a the MAP 255 Walbro intank pump. I no for a fact making 550whp+ on E85 a single 255 will not cut it.
So my question is what kind of pumps do people run to support 550whp on E85. My friends wants the easiest one to install. Like a drop intank one would be best if someone makes one.
His injectors are 1680cc so he has plenty of injector.
Old Jan 2, 2013 | 10:42 AM
Eg6(s)'s Avatar
Double pumpers..
other options are the aeromotive 340 and walbro 460 e85 pumps specifically for E85
Old Jan 2, 2013 | 11:04 AM
Originally Posted by Eg6(s)
Double pumpers..
who sells the double pumper? link plz!
nvm i found what i need.
Old Jan 2, 2013 | 07:33 PM
scheides's Avatar
EvoM Moderator
Two options both making 600whp dynojet:
my setup: Walbro 400 + BAP + boomba racing
murlo's setup: Walbro 400 (e85 version) + upgraded feed line.
I'd honestly throw in a W400/E85 and just see how it works. I'm running the FIC 1680's and made 550whp with my BBX on a W300, BAP, and stock fuel rail/lines. Try it with the W400 and if that doesn't cut it, consider upgrading the fuel rail or throwing a BAP at it if that doesn't cut it alone.
Old Jan 2, 2013 | 07:48 PM
RussellDaniel's Avatar
I was just worrying about this same thing today. thought about going the walbro 400 route,but the more i think about it, im just gonna bite the bullet. Get the bushur double pumper, and the fic 2150's and call it a day.
Old Jan 2, 2013 | 11:17 PM
murlo26's Avatar
This
Old Jan 3, 2013 | 06:51 AM
DevilDog7's Avatar
I'd honestly throw in a W400/E85 and just see how it works. I'm running the FIC 1680's and made 550whp with my BBX on a W300, BAP, and stock fuel rail/lines. Try it with the W400 and if that doesn't cut it, consider upgrading the fuel rail or throwing a BAP at it if that doesn't cut it alone.+1
Im Running a Walbro 400 pump, boomba racing fuel rail, and FIC 1100 injectors and im built with an ef4. I run 93 and 110 octane though, not e85. I would recommend the same setup with bigger injectors. Works good for me.
Old Jan 3, 2013 | 07:08 AM
Devildog how much power are you pushing right now on that setup?
Old Jan 3, 2013 | 07:15 AM
DevilDog7's Avatar
Havent dynoed it yet. Should be around what the OP is looking at.
Old Jan 3, 2013 | 09:51 AM
Eg6(s)'s Avatar
There is also this bad boy...
https://www.evolutionm.net/forums/sh...d.php?t=633779
Nadaevo
Mar 3, 2016 06:28 AM
maperformance
Oct 18, 2014 11:16 AM
mr evo7
13
Feb 7, 2014 07:23 AM
evo8cody
Nov 15, 2013 09:10 PM
Randal
Oct 6, 2013 09:44 AM
