Sponsored by:
Sponsored by: CARiD
View Poll Results: Stickie this thread?
Yes.
100.00%
No.
0%
Voters: 2. You may not vote on this poll
Stupid Questions Thread
Old Mar 11, 2013 | 07:49 AM
  #31
Thomar's Avatar
Can someone explain this E85 for me? As far as I know the evo requires 91 octane or higher. Some of you run Ethanol 85 gas, yes? So, if available in my area, I can get a tune for E85, and expect to get more horse power out of it then 91 octane?
Also, does the car use more fuel running on E85?
Old Mar 11, 2013 | 08:04 AM
  #32
Raptord's Avatar
Yes, the car uses more fuel on E85. You generally need upgraded injectors and an upgraded fuel pump to run E85 since you need to burn more of it (roughly 15% if I'm not mistaken).
Old Mar 11, 2013 | 08:06 AM
  #33
Thomar's Avatar
I see..
So then, from what I've read so far, to get better fuel economy out of the X, different intake, better tune?
Old Mar 11, 2013 | 08:19 AM
  #34
ogrenator's Avatar
evo and fuel economy should not be in the same sentence but yes a tune would help...cobb has economy maps for the AP too
Old Mar 11, 2013 | 08:23 AM
  #35
Thomar's Avatar
k, thanks.
Old Mar 12, 2013 | 06:12 AM
  #36
CaptainAsia's Avatar
I run the economy maps on the AP for my daily commute. Makes a difference by a lot. Like 25 to 30 mpg, but no power lol...
Old Mar 19, 2013 | 03:23 AM
  #37
MisterHappy's Avatar
I keep seeing people talking about oil catch cans and selling them. Heard with me running E-85 it would be a good idea to get one, why?
Old Mar 19, 2013 | 04:07 AM
  #38
evokid4life's Avatar
I think its a little bit more towards the 25% area for e85
Old Mar 19, 2013 | 08:14 AM
  #39
Veronica's Avatar
The oil catch can keeps oil being drawn back into the intake system through the positive crankcase ventilation (PCV) system. On boosted cars (or any car with bad compression seals) the combustion pressure leaks into the crankcase and blows oil with air as it is drawn into the intake for emmsions (it used to just be vented to the atmosphere).
Short answer - if your intake system is clean, with no oil fouling - then you do not need an oil catch can.
(yet)
Old Mar 19, 2013 | 08:25 AM
  #40
(yet)
How does one know if the intake is clean?
Old Mar 19, 2013 | 08:27 AM
  #41
Raptord's Avatar
You take off the intake and check if it's clean.
Old Mar 19, 2013 | 09:01 PM
  #42
Thatotherguy's Avatar
Can I just short the fuel pump relay so it's always running at max voltage and not deal with a faulty relay blowing the motor?
Old Mar 20, 2013 | 08:36 AM
  #43
Veronica's Avatar
No.
The pump would run even with the car key 'off'...
It is also for safety - computer shuts it off in a roll over/collision...
Best fix is a new relay.
Old Mar 20, 2013 | 09:21 AM
  #44
O'Brien113's Avatar
so totally off topic but I just bought a 09 GTS and am weighing pros and cons of different upgrades. I want a good performance boost but don't want to kill my mpg (this is my commuter) what upgrades will benefit me the most?
Old Mar 20, 2013 | 09:47 AM
  #45
Raptord's Avatar
You'll have better luck and more people familiar with your platform in the Lancer section.
