Sponsored by:
Sponsored by: CARiD
View Poll Results: Stickie this thread?
Yes.
100.00%
No.
0%
Voters: 2. You may not vote on this poll
Stupid Questions Thread
Old Jan 17, 2015 | 10:39 PM
  #91
Thomar's Avatar
Originally Posted by CyberPitz
Ah, a thread where I can get the questions I'm too scared to ask off my chest!
Whenever I first start to drive my car, while pulling away in first gear, right before I fully release the clutch I hear a loud 'clunk' near my front driver side wheel. Is that normal or should I go to the dealer for a quick check? 14 GSR with 5200 miles.
Ya I think it's the limited slip differential, but I don't really get a clunk either.
Old Jan 18, 2015 | 06:14 AM
  #92
Ancyker's Avatar
Are you 100% sure it's the front? I've had that issue, but it was from the rear and only when it was wet out when I parked, and cold when I was trying to leave. The brakes can freeze to the rotors when it's very cold out, usually it's the e-brake that freezes since it's left on. When the car starts to move the thin layer of ice is broken, that suddenly releases the brakes = clunk. This is not a good thing, it's hard on the braking system.
If it's happening every time you park, you can rule this out by applying the brakes while still moving. So stop a little short (a foot or two) of where you want to park, then while braking (NOT hard braking, just enough that you feel resistance) apply enough power to get you into the spot. This squeezes any water out and prevents that from happening.
If this turns out to be the issue, make sure you do it every time. Releasing the frozen brakes by moving the car causes excessive strain on the calipers. It's no different than trying to move your car with the e-brake fully engaged.
If that's not it, take it in for service. That's what the warranty is for.
Old Jan 24, 2015 | 09:07 AM
  #93
newevoxguy's Avatar
I have a question. What do you torque the bolts to that go from the turbo to the down pipe?
Old Jan 27, 2015 | 07:36 PM
  #94
Thomar's Avatar
If it's exhaust bolts, I think it's like 60ft/lbs.
Old Apr 6, 2015 | 07:44 AM
  #95
Thomar's Avatar
Bump
Old Oct 20, 2015 | 10:37 AM
  #96
Thomar's Avatar
Bumping for love.
SE7ENEVO
Sep 9, 2021 11:03 PM
Masterr
Feb 25, 2016 05:48 AM
