Sponsored by:
Sponsored by: CARiD
I have some evo x headllight questions.
Old Mar 26, 2013 | 09:34 PM
brakedrift1217's Avatar
I've searched through many places(google, here and there) but couldnt find the answer to my question.
Can we use lancers headlight to lancer evolution x(im talking about the lancers hid projector headlight since I have gsr with halogen headlights)? If yes, then will there is any issues such as flicker etc. really hoping this to be plug and play since lancer and evolution to have same flatform in and out.
If lancers headlight dose not fit in evolution then im thinking of getting depo headlight and change the projector lense to something clear. Will this change help the projector to have better cut off, light pattern? cuz I heard depos projector will scatter and blind the others.
Thank you for your time.
Old Mar 27, 2013 | 06:48 PM
sun_ice4's Avatar
I considered the same thing you are doing, but ended up doing my own retrofit. It's not just plug and play. I looked at some OEM HIDs awhile back, my memory may be failing, but something sticks in the back of my mind that there was some small difference about the wiring, or hookup, or the auto leveling. Someone else may be able to chime in here to say otherwise. I do know that if your GSR halogens have day time running lights, you will have to disable them, otherwise you'll get flicker. The JROX cable works perfectly.
As far as fitment, Lancer and EVO's are the same casing, bolt hookup, and guts.
Old Mar 28, 2013 | 04:05 AM
kalpakiotis's Avatar
the evo headlight has a single bulb for lo/hi and uses the auto-level shutter to toggle between the two. The lancer has two separate bulbs, and uses the lo as the DRL. You could do it, but in essence you would lose your hi-beams if you use the evo wiring on a lancer housing.
Old Mar 28, 2013 | 11:13 PM
I have 2011 gsr which also has two separated headlight and does not have drl. so will it be worth try?
Old Mar 29, 2013 | 01:05 AM
carnfghj's Avatar
Old Apr 1, 2013 | 08:59 AM
spikester603's Avatar
I am Brit Army stationed in Germany and we are required to meet EU car testing standards ie we need left hand drive headlights installed in our Right hand drive UK cars.
I'll cut to the chase... I had to remove my UK xennons and no way was I gonna fork out 1100 euros for some EU ones just to pass a test. I bought some cheap Lancer GS headlights and installed them in my Evo X, they are plug and play. The only problem I have is I have to turn off the AFS button (addaptive front lighting system) the feature that turns on the corner lights. If you dont turn it off you get a warning pop up on the display and it wont go away until you disconnect the battery.
so I basically I plugged in Halogen headlights to a Xennon system and there's no problems, everything works fine, no flickering etc.. so I assume it would be fine the other way around, as the wiring loom is no different all the differences are on the back of the headlight.
does that make sense?
hope that helps.
Old Apr 1, 2013 | 08:35 PM
thanx everyone for ur inputs. imma gonna get depo and just change the lense and call it a day. im pretty sure that its going to give me enough light to drive in dark
Unknwn
Jan 26, 2019 07:13 AM
commbubba19
Mar 9, 2016 06:41 AM
jzralliart
Feb 21, 2016 06:48 AM
LancEric
08+ Lancer Show / Shine
44
Feb 3, 2015 01:52 PM
Feyasco1031
Apr 11, 2010 07:00 PM
