Sponsored by:
Sponsored by: CARiD
For those of you with ACD pump failures (merged)
Old Jul 2, 2013 | 01:59 PM
  #61
spekil's Avatar
Mine is not an Evo X, just Ralliart. Anyways, my awd warning light keeps turning on everytime I start the car. So I'm assuming that my ACD pump is also toasted. Mine is 09 Ralliart with 103,000kms.
Old Aug 14, 2013 | 01:51 PM
  #62
EvoVIII_03's Avatar
All Wheel Pump Failure
What's up guys. I'm in need of some help/advice. On Sunday as I was driving around town my sister (sitting on the rear passenger side) said she noticed a nice that sounded like a cell phone left on vibrate. So, I turn down the music and sure enough it sounded like a pump was working to hard. I left the noise, and eventually it went off, but right after the Service required came on the dash. I took it in to the dealer, and said I needed a new hydraulic pump and that the part itself is 2100. My car is a 2010 GSR with 25,000 miles. Ive read all post made related to this and seems that most pumps go out during the winter, except mine went out during summer time. I was planning on getting a three day vacation (mini vacation) but my question is can I still drive the car, but not do heavy driving? Im usually a normal driver.
Thanks guys
P.S. Dealer denied covering it under warranty, which I think is messed up to us evo owners since most of us experience this problem at a low mileage
Old Aug 14, 2013 | 02:07 PM
  #63
CaptainAsia's Avatar
Mine is starting to go too, did you throw a code? I heard that it shouldn't break anything else when it goes but I will be calling my tuner once it goes out.
Old Aug 14, 2013 | 02:31 PM
  #64
EvoVIII_03's Avatar
As of today I still haven't hooked up my scanner to see if its throwing a code. But, ill try putting it on today and see if theres a code, and then ill report.
Old Aug 14, 2013 | 02:47 PM
  #65
Iowa999's Avatar
I'm sorry about your pump, but the following simply isn't true.
Go here https://www.evolutionm.net/forums/ev...e-reports.html and note that pumps can fail at any time of the year.
Old Aug 14, 2013 | 02:48 PM
  #66
Iowa999's Avatar
A plain scanner can't read the codes for a dead pump. You need something like AccessPort, MUT, and, maybe, EvoScan.
Old Aug 14, 2013 | 04:01 PM
  #67
EvoVIII_03's Avatar
Ahh I see. Not even a Snap On Modis Scanner?? If it can run system test thanii don't why it should pick up a simple code. Ill give it a try though.
Old Aug 14, 2013 | 04:27 PM
  #68
illogicalmind's Avatar
I just heard about acd-tuning.com from a friend the other day. They will rebuild it for you pretty cheap (compared to a new one). I dunno if that helps u out any, but they seem to be pretty knowledgeable with these things
I hope that doesn't break any rules. I don't feel like searching for them and leading u around the forum more.
Old Aug 14, 2013 | 05:06 PM
  #69
EvoVIII_03's Avatar
Thanks man I really appreciate it you did enough just by telling me about them thanks my one and only question is will I still be able to drive without any problems. If this helps I don't race or autocross.
Old Aug 14, 2013 | 05:08 PM
  #70
EvoVIII_03's Avatar
This is the code I got C161E AWC Pump
Attached Thumbnails For those of you with ACD pump failures (merged)-20130814_182804.jpg
Old Aug 14, 2013 | 06:42 PM
  #71
Snagtooth's Avatar
The picture made things pretty clear, what now?
Old Aug 15, 2013 | 12:31 AM
  #72
Iowa999's Avatar
There is no problem driving with a dead pump. It will remind you of having a DSM without a rear VC, in fact.
Old Aug 15, 2013 | 10:56 AM
  #73
TrogdorWBL's Avatar
It's totally safe to drive with a bad ACD pump, don't worry!
Old Aug 15, 2013 | 01:33 PM
  #74
trick3d's Avatar
can it damage anything else further by driving with a bad ACD pump?
Old Aug 15, 2013 | 04:04 PM
  #75
Iowa999's Avatar
I'm not sure how many more ways we can say it, dude. The answer is No.
