Sponsored by:
Sponsored by: CARiD
Ets intercooler +piping needing a re tune?
Old May 18, 2013 | 09:43 AM
bob2004's Avatar
Thinking about replacing my intercooler since some one backed into my bumper and bent my intercooler a bit, so my insurance is covering the price of stock ($700) lol. So I'm thinking whats the point, might as well upgrade a bit. Would I need a tune on 2012 gsr? or a re-tune since I have stage 2 cobb ap with hfc and cat back. Sry if it was mentioned somewhere, I did try searching and I found for 2008 model stock tune.
thanx
Old May 18, 2013 | 10:11 AM
bstgsr's Avatar
^ Very interesting explanation... Yes, It would be safer if you had your car tuned after changing all those parts.
Old May 18, 2013 | 11:49 AM
MisterHappy's Avatar
thanx
No you don't NEED a tune. Your car will run fine with the new parts added, but if you want to take advantage of the power of the new parts you will need to be tuned for them.
Old May 18, 2013 | 11:57 AM
BCOZEVO's Avatar
What about adding a IC and pipes would make you think he does not need a retune? Increased air flow + boost charge - stock AFR settings = lean conditions
Just my 0.2
Changing anything engine related requires some ROM attention, even down to a intake. If you ignore it and just hope for the best you most likely just going to get the worst.
Old May 18, 2013 | 10:25 PM
spatel133's Avatar
yes you need to retune. since you have cob, have them send you out another map .
Old May 19, 2013 | 12:38 AM
misterevo8's Avatar
simular problem with my buddies evo he ended up getting it tuned with his ic and piping.
Old May 19, 2013 | 08:53 AM
Just my 0.2
I ran mine for 6 months, talked to tuners about this issue as well. Will it be ideal? No. Can you run it safely? yes. Am i just giving my .02 and hoping for the best or did i ask people that knew the answer? yes.
Old May 29, 2013 | 11:53 AM
EvolutionHolly's Avatar
My friend haven't tuned his car after he put the IC in, just give your ECU some time to learn but yes you should definitely get it tuned.
Old May 29, 2013 | 01:13 PM
mirkendargen's Avatar
Do you need a retune when it's cold outside? That's what a better intercooler is doing for you. Sure there will be increased airflow, which the MAF sensor will detect. Intercoolers and intercooler piping won't throw off the MAF sensor calibration like intakes potentially can.
The better intercooler may allow you to run more boost and/or timing without knock, which you WOULD need a tune to take advantage of.
WRC-LVR
105
Jul 28, 2017 09:39 AM
stlgrym3
14
Aug 28, 2014 06:53 PM
UMIR3N
Nov 20, 2013 03:14 PM
khmerguyx
Oct 4, 2013 07:07 AM
Evo1001
Jun 21, 2010 10:22 AM
