Sponsored by:
Sponsored by: CARiD
need advice engine rebuild
Old Dec 17, 2013 | 02:52 AM
mco-evox2008's Avatar
Question need advice engine rebuild
cylinder # 3 has a compression of 80psi and all the rest cylinder are fine ....i want to rebuild my engine /head and block my goal is 500 on pump gas 93
Old Dec 17, 2013 | 03:46 AM
MR. EVO MR's Avatar
In my 8 when I blew the head gasket I had a reason to rebuild by engine to lol.
I did a dropin, wesco pistons, tt rods, 272 cams, springs and retainers.
Had her at 542whp and almost 500wtq.
Don't go to laggy on the turbo.
GL!
Old Dec 17, 2013 | 08:37 AM
Showbizz41's Avatar
This isn't in the form of a question. What exactly are you after for info?
Old Dec 17, 2013 | 03:02 PM
joeyorav's Avatar
I have experienced first hand the disasters wrought by well meaning but inexperienced people rebuilding their engines.
It can however be accomplished. You should hook up with a friend that has experience with engine rebuilding and have them guide you through the process or there are many good books available that should be reread time and time again before beginning the process.
Three books to read, available from Amazon, would be:
How To Build Max Performance Big Blocks by Andy Finkbinder
Big Block Mopar Performance by Chuck Senatore
How To Rebuild Big Block Mopar Engines by Don Taylor
I recommend having an experience engine builder do the engine, UNLESS you have burning desire to do it yourself, AFTER reading the above books.
Old Dec 17, 2013 | 07:39 PM
Snagtooth's Avatar
So I guess the question would be are you considering rebuilding it yourself or having a shop do it for you? What modifications to the engine would you consider?
I agree that reading and understanding the process of an engine rebuild is very important, but it should be known that you are referencing sources for domestic automobiles.
But, I'll trust your judgement and check-out these sweet-books, thanks
Old Dec 17, 2013 | 07:47 PM
Napalm_Enema's Avatar
What causes the HG to go on an EVO? I know that's a fairly common issue on Subaru's but wasn't aware it was seen frequently on EVO's?
Old Dec 18, 2013 | 11:32 PM
Smile
my question is what would be the best set up to have daily driver and still have ...safe engine with 500whp....
1. Manley "I-Beam" Connecting Rods
2. ARP Headstuds /main studs
3. Oem Headgasket
4. Wiseco piston or Manley Forged Pistons
5. GSC Power-Division S2
6. GSC Beehive Valve Springs Titanium Retainers
7. Supertech SS Valves Black Nitrided
Old Dec 20, 2013 | 09:03 AM
nolimits1320's Avatar
Odd reading recommendations.
94AWDcoupe
41
May 28, 2017 09:06 PM
Montu
39
Sep 12, 2016 10:25 AM
insafa
Aug 18, 2015 06:51 PM
pukka
Jun 25, 2013 11:13 AM
dsci4
West Region
20
Jun 2, 2010 11:18 AM
