Sponsored by:
Sponsored by: CARiD
FAST key low battery
Old Jan 20, 2014 | 01:11 PM
WarmMilk's Avatar
so my little info display in the guage cluster has been showing low battery on my FAST key for a few weeks now. So I took the battery out of second key and put it in the first. But it still shows low battery when I start the car.
The reason I switched the battery instead of just using the other key is cause I have a Python alarm/remote start installed on my car and it can only link with one key.
Is there anything that needs to be reset when I change the battery or should it reset by itself? Anyone have any suggestions for me?
Old Jan 20, 2014 | 02:54 PM
slim64's Avatar
I had the same issue ..without the alarm with remote start.. All you should have to do is replace the battery with a brand new one from radio shack or where ever.y and the message should go away on the display(this happens with my 2010gsr)
Old Jan 20, 2014 | 03:32 PM
WarmMilk's Avatar
did it go away from the next time you started back up or did it take a while to catch on that you have a new battery in there?
Old Jan 20, 2014 | 04:18 PM
DGS's Avatar
DGS
... So I took the battery out of second key and put it in the first. But it still shows low battery when I start the car. ...
If you've had the batteries in both keys all this time, it could be that *both* batteries are low.
I had to take the battery out of the spare key. The car gets really confused if the spare key is in my briefcase, in the trunk.
I tend to stock up on those batteries -- my garage door remotes use the same batteries.
They're available pretty much everywhere.
Old Feb 5, 2014 | 06:29 PM
Ralliart09er's Avatar
Had that happen but without the alarm system. I just tried to only using the key to start the car. Car went ape **** and shut down on me without turning over until I got a new battery for it.
2009RGRalliArt
Jun 19, 2020 02:31 AM
ChikChik
Apr 7, 2018 04:44 PM
yeayeaatou
Feb 7, 2016 08:52 AM
gizmotoy
Sep 17, 2015 12:12 PM
bmoresauter13
Mar 23, 2011 02:47 PM
