Sponsored by:
Sponsored by: CARiD
P1025 - Exhaust engine oil control valve circuit
Old Feb 1, 2014 | 04:24 PM
dragon831's Avatar
I recently installed a new fuel rail, fpr, and a few other things. Started the car up today and it immediately threw the P1025 (Exhaust engine oil control valve circuit) code. I went back to all the connections that I taken off and made sure I had put them back on tight. Any know exactly where the wiring is for this?
Old Mar 20, 2014 | 11:24 AM
fourg63tgsx's Avatar
Possible oil control valve find.
I am not to sure where to put this information.
I also have the p1025 code and was able to verify the solenoid to be defective. Long story short I believe the 2008 Dodge Caliber has the same valve on the 2.0 motor for much cheaper. The pictures the dealer sent me appear to be the same on my 08 gsr. I will pick it up tomorrow (3/21/14) and verify it is the same part. If this is true plan on saving 200 bucks from not using the mitsu dealer. Here is a link
Pull up the image and look at part number 10 and 7
http://www.factorychryslerparts.com/...ssembly=540337
Old Mar 21, 2014 | 06:26 PM
It Worked
Good news, after getting my hands on the dodge part I found them to be the exact same. Installed it earlier, cleared the code with cobb and have put on 100 miles with no code.
Old Mar 21, 2014 | 07:35 PM
Johnr352's Avatar
what is the Dodge part number vs the Mitsu part number
Old Mar 22, 2014 | 01:57 PM
The dodge part number I used was 04884483ac the mitsu part number is 1028A022 ( for the exhaust)
Old Mar 22, 2014 | 05:08 PM
Johnr352's Avatar
You are a rock star. Thanks
Old Mar 23, 2014 | 07:45 AM
No problem
Glad to see it helped at least one person. Hope it solves your problem. I know if you buy the dodge part off line you can get it even cheaper than I did.
92 GSR-4
May 9, 2014 10:08 AM
Megaapple31
Nov 11, 2013 07:26 PM
WikdEvo
Jun 20, 2013 08:25 PM
babaz7
Jul 6, 2012 09:23 PM
criptballer
Jun 30, 2010 12:21 PM
