Sponsored by:
Sponsored by: CARiD
springs question
Old Feb 12, 2014 | 06:51 AM
CaptainAsia's Avatar
springs question
Question, so my buddy got swift springs on his MR and gave me his stock ones. Will they fit on my GSR, too cheap right now to buy new springs (also need to look at if I want to do that or coilovers) and I have about 100k on my stock ones so they are getting a little soft. Will they fit and/or run like ***? Thanks in advance!
Old Feb 12, 2014 | 01:41 PM
kevinlambchops's Avatar
https://www.evolutionm.net/forums/ev...art-evo-x.html
Springs ...................... Front Rate ........ Rear Rate ...... Front/Rear Drop ...... Street Price
Stock GSR ...................... 3.5 kg ........... 2.8 - 3.7 kg .......... 0.0" / 0.0" ................. OEM
Stock MR ........................ 3.5 kg**........ 2.9 - 3.8 kg .......... 0.0" / 0.0" ................. OEM
They are pretty similar, I believe the shocks are different though
Old Feb 16, 2014 | 04:02 PM
So I'm taking it they won't fit then?
Old Feb 16, 2014 | 06:45 PM
franzcars's Avatar
They should fit, the only thing is they might ride a little rougher due to the MR being heavier so they need to be stronger. Also the shocks fit the same, since the bilstines are a common upgrade for GSR's
Old Feb 17, 2014 | 12:40 PM
what franz said. The shocks are the same but an upgrade I believe. And the springs should fit just different rate, a little bit heavier.
Old Feb 18, 2014 | 01:27 PM
KVandy15's Avatar
Related question if you don't mind a little derailing...
I've got an MR and I'm looking to do some minor suspension upgrades for autox. I was thinking about new sway bars or some other stiffening but a lot of people tell me to do coil overs.
Given that I have the MR suspension are coil overs still that high on the list?
I should also note that I'm not willing to give up ride height, I drive the car year round, often in heavy snow, I don't want it to be any lower.
Old Feb 19, 2014 | 02:52 PM
powerman00's Avatar
i don't think the mr springs offer any advantage of your stock ones. Nothing you would notice anyways
Old Feb 19, 2014 | 04:58 PM
Iowa999's Avatar
Imma let you finish, but if any of you can detect a 0.1k change in rear springs, you have the Kim Kardashian of butt-dynos. (And I mean that in a good way, even if I just threw up a little in my mouth.)
Old Feb 19, 2014 | 09:08 PM
yah what iowa said LOL
Thahomeboyb
Aug 5, 2014 09:06 PM
CaptainAsia
Apr 16, 2013 12:16 PM
EVO IXMR
13
May 21, 2011 05:34 PM
EVOXMR10
Apr 5, 2011 12:35 PM
Go_Lancer_Go
Sep 9, 2005 09:11 PM
