Sponsored by:
Sponsored by: CARiD
Aem failsafe vs aem uego
Old Apr 27, 2014 | 11:37 PM
iLLuZioNSmurF's Avatar
So just wanted to make sure I got this right, the failsafe is basically a boost gauge / AFR gauge in 1 which you can log for up to 3 hours etc etc? and Uego is obviously just a regular wideband with nothing special for logging purposes etc... If I was to go with the tactix cable and evo scan would I really want the failsafe though as I can log on the laptop?
Old Apr 28, 2014 | 07:45 AM
turbotboz's Avatar
I cant speak on behalf of the fail safe gauge. But the Uego does have a 5v output that can be logged in evoscan using the rear o2 input or another similar input.
Old Apr 28, 2014 | 09:05 AM
10isace's Avatar
I've tried this with the AEM UEGO in the 8/9's with 4 different formulas I found online, but none of them read correctly. I know this is for an X, but does yours read correctly?
Old Apr 28, 2014 | 11:29 AM
turbotboz's Avatar
hmmm. I havent set it up in this car yet (its under the knife). But in my previous 8 it was working well. This is a little off topic, but are others having the same issue?
Travis
Old Apr 29, 2014 | 10:20 PM
m0nkie's Avatar
I can tell you that the fail safe is a PAIN IN THE *** TO INSTALL...
I managed to hook up the AFR/Boost and Uego.. can't figure out how to hook up the fail safe.. so i just left it.. LOL..
talked to a few AEM fail safe owners.. all of them did the same thing, left the fail safe uninstalled..
Old Apr 30, 2014 | 12:48 PM
Scott@HKSUSA's Avatar
No different than installing a boost gauge and a wide band. Except both gauges are combined so only 1 power and ground for both.
When we had Motovicity's Subaru on Cobb, I didn't really have anything to run the failsafe output to, but I didn't want to waste the feature so I just ran it to the glove compartment light. lol One could get creative with that output if desired.
If you're on a stock ECU and boost control, it's going to be a challenge to make the failsafe feature useful. But no one said you have to. Even without using the failsafe output, it's still 2 gauges in 1 + a datalogger.
Old Apr 30, 2014 | 04:08 PM
maybe make it kill my stereo so if im not paying attention ill just be like WTF! then be like Oh **** lol
Old Apr 30, 2014 | 07:35 PM
ChrisWantsBoost's Avatar
I've had the failsafe for awhile now, it's actual failsafe feature does baffle me though. I tried to do research on the subject, and there's not too much information that I can utilize. The radio option does sound interesting. I might have to try to destroy my radio one weekend.
Old May 1, 2014 | 01:15 AM
mavraolan's Avatar
I was about to buy the aem v2 w/m but without the failsafe. I also make some research to find any other ways as failsafe but there aren't any information.
Radio and glove compartment light thought are the first things I ever read....lol...
Old May 1, 2014 | 10:36 AM
Think of it like this: the failsafe output is just a 0-5V on/off switch. You set the on/off thresholds in the Failsafe software. Whatever the switch turns on/off is entirely up to you. It's not indended to be specific to any one car or device.
So for example, if you were running a stand-alone ECU (like a AEM EMS), you would run the failsafe output to a 0-5V input on the ECU. When that ECU input sees 5V, you set it to trigger a retarded (NOS) timing table that you would have set up.
Or, you could set that ECU input up to trigger a boost trim map (with no boost) when it sees 5V. Or fuel cut. Or ignition cut.
Or, with some stand-alone boost controllers, you could directly trigger a solenoid to open the WG.
Or, you could power your own warning light on the dash or cluster.
Or, you can turn the glove box light on & off. lol
I hope you can see where I'm going with this. What it does is entirely up to you.
Old May 1, 2014 | 11:07 PM
m0nkie's Avatar
ahhh thanks! This helped a lot.. even tho the function of it doesn't seem that useful.. the 2 gauges work really nice tho!
Ambiguous
Oct 17, 2014 07:58 AM
MRak
Mar 12, 2014 06:46 AM
Metal
Nov 7, 2012 09:24 PM
Andrew@AMS
Automotosports - Illinois
Sep 18, 2012 07:01 AM
karwh0re89
Sep 13, 2012 08:37 PM
