Sponsored by:
Sponsored by: CARiD
Evo x mr question!
Old May 1, 2014 | 11:06 AM
datevox's Avatar
Evo x mr question!
Hello im new here....Does anybody know why my evo x shifter wont slide over to manual mode or to the +/- it seems like its locked but it drives good not tranny issues at all what could it be the problem.
Thanks in advance
Old May 1, 2014 | 11:09 AM
DownSideFX's Avatar
That's odd, should pop right over without much force. Paddle shifters work? I wonder if something is obstructing it, might need to lift up the console to check underneath.
Old May 1, 2014 | 11:19 AM
datevox's Avatar
Yeah the paddle shifters work fine it happen to me a couple times it did that but it went back to normal after couple hours but now it just stays there.
Old May 1, 2014 | 01:43 PM
Risky Guy's Avatar
Never ran into an issue with the x. My last car, the electronic module that would take the trans from auto to tiptronic. It would only act up when cold. One of the hardest problems to diagnose, since it wasn't constant. It sounds like the shifter itself maybe bad. Good luck with getting it sorted out.
Old May 3, 2014 | 03:04 PM
strickland3114's Avatar
Bump
Old May 3, 2014 | 04:53 PM
DGS's Avatar
DGS
Silly thought, but maybe something dropped into that side slot that's blocking the shifter from moving over.
Have you tried passing a magnet over the slot?
Have kids?
Old May 5, 2014 | 09:51 AM
KVandy15's Avatar
I had an issue with mine where sometimes when I would move it over it wouldn't actually engage the manual mode or would sporadically flip between manual/auto the two. I took it to the stealership and they replaced the shifter mechanism under warranty, problem solved.
It sounds to me like you are having a different issue though, I've never heard of not being able to move the shifter over, mine pops right over. I'd suspect a mechanical blockage of some kind. I'd be taking it apart to have a look, could be a clip or tab that broke/fell off and got into the mechanism or something like that.
Old May 5, 2014 | 12:44 PM
ikt's Avatar
ikt
probably a french fry stuck in there
Old May 5, 2014 | 01:26 PM
Corrupter's Avatar
Thanks in advance
Was it working when you got the car, or did it just start happening suddenly?
jlldetroit
For Sale - Part Outs
Jun 2, 2015 08:20 PM
krypt952
May 17, 2015 03:35 PM
I NEED BOOST
Sep 24, 2012 12:11 PM
