Delay between accelerator pedal and revs
Hey guys,
On my X, there is a delay when in neutral between me tapping the accelerator pedal and the rise in revs. I was just wondering if other people experience the same thing and what the reason for this is in the Evo X?
I am not having any issues with my car at all and was just curious about this...
Thanks
Thanks
More like most fly by wire accelerators aren't as responsive as the good old fashioned throttle cable variety. Just takes a moment for the computer to read the throttle position and produce an appropriate response.
If you think the Evo is bad, try driving a mid 2000's era Toyota. It was so bad on those that it manifested itself as unintended acceleration at some times. Experienced it on my old Camry Solara.
Hey guys,
Thanks
Thanks
I have basic bolt ons and a tune by RRE. I believe that the car still had this delayed pedal action even before my car was modified. But thanks for the suggestion in case something goes hay-wire in the future.
It's probably just the "computerized" response... same deal on my 08' Gsr before mods.
After putting on the basic bolt ons - throttle seemed to be a bit better but not by much.
The solution I used was Sprint Booster => super easy to install [plug-n-play] and increase response dramatically.
Thread Here ===> https://www.evolutionm.net/forums/ve...sr-review.html
You can use ECUflash to change the throttle tables in your ecu to something much more responsive. I did this about a year ago and still no problems. It has much improved the throttle response delays.
Check out this thread.
http://www.evoxforums.com/forums/showthread.php?t=54910
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
tequila357
Feb 18, 2016 11:42 AM
Z06Samuel
May 21, 2011 04:04 PM
