Sponsored by:
Sponsored by: CARiD
gurgling sound when letting off the throttle...
Old Jun 24, 2014 | 06:36 PM
ChipperEvo's Avatar
So I have recently had some issues with SES and codes popping up on my 11 GSR. I am still working on what is causing the codes to pop (P0012 and P0017) but have another concern.
I don't know if I have just never noticed or if it just started happening but I hear a very faint gurgling sound when I let off the throttle around 3500 RPM in 3rd and 4th gear. I tried to capture it in video but just can't get the sound to record right. Anyone else notice this? Do I have an exhaust leak?
Old Jun 28, 2014 | 11:03 AM
ChipperEvo's Avatar
No one?
So the sound is more of a dododododododo instead of a smooth dooooooooo when you let off the gas. Anyone else hear this?
Old Jun 28, 2014 | 10:34 PM
hispanicpanic's Avatar
Sounds like a lot of doodoo. Better check your pants.
On a related note, have you replaced your fuel pump relays?? They tend to go bad.
Old Jun 29, 2014 | 07:41 AM
Iowa999's Avatar
When someone says that their turbocharged car makes any kind of fluttering or gurgling noise when they lift off the gas, I immediately wonder if they have an aftermarket compressor bypass valve (aka diverter valve, aka [incorrectly] blow-off valve) that isn't set properly. But I don't see that mentioned in your signature.
The P0012 and P0017 is a bit more worrisome that an off-throttle noise. There's a chance that you've stretched your chain.
Old Jun 30, 2014 | 08:51 PM
ChipperEvo's Avatar
I suspected a stretched chain so I took it into a dealer and they said the chain is fine...tried swapping the sensors (intake to exhaust) and vice versa and only the exhaust code comes on so the sensors seem fine too.
I took the valve cover off and did a visual check on the chain after the dealer to verify and it seems fine (forgot to do the TDC part though...arrrggghhh). the car runs fine and idles smooth as I mentioned...
I have no idea what to do now other than maybe change the oil control solenoid to see if that is faulty.
no aftermarket BPV here, just thought it was weird I started to hear the sound after I started getting the codes. probably nothing.
been trying to get a hold of STM in Rochester to take a look but man those guys do not know how to return a call. 2 calls and 3 emails later, still no reply from STM. I guess they don't want my business.
Can you tell how bad the timing is being retarded from AP logs?
Old Jun 30, 2014 | 08:53 PM
ChipperEvo's Avatar
good point. i will check that too. can a faulty pump or relay cause timing to retard enought for a code?
Old Jul 1, 2014 | 06:08 AM
Kendogg's Avatar
Well I know it causes lack of fuel when under WOT or at a certain amount of throttle. But you should be able to tell assuming you have a wideband. Either way it doesn't hurt to change out the FPR. They are not that expensive and personally I change mine out every year, along with my plugs.
Old Jul 1, 2014 | 09:49 AM
ChipperEvo's Avatar
Yeah I have some new spark plugs on the way from MAP and will check the relay today after work.
I did some logging on the way home last night but didn't see a log setting for timing retarding. just ignition advance and target. Anyway to tell if the timing is being pulled too much from these logs?
File Type: zip
jheff
Jun 11, 2020 01:23 PM
fritobandito24
Lancer Troubleshooting
Aug 4, 2013 09:00 AM
Decepticon1225
Lancer Engine Tech
Jul 29, 2012 01:58 AM
Mitsu.kid.02
Aug 16, 2011 06:22 PM
Xearo
Mar 10, 2011 10:47 AM
