Sponsored by:
Sponsored by: CARiD
HELP: tranny bolt
Old Aug 17, 2014 | 07:47 PM
Kartyman550's Avatar
HELP: tranny bolt
The bolt in the middle of this picture; how much do you torque it too.Its the bolt between drain and fill. Thought it was the drain bolt for the traanny and turns out that t isn't. Also does anyone know what it does???
Thanks
Attached Thumbnails HELP: tranny bolt-screen-shot-2014-08-17-8.45.54-pm.jpg
Old Aug 18, 2014 | 08:36 AM
Veronica's Avatar
Use same torque as the drain plug.
It may just be a magnetic plug solely to trap material at that point.
I would recommend pulling that plug/clean/inspect it as part of the servicing each time...
Old Aug 18, 2014 | 09:28 AM
Burnhad91's Avatar
The bolt you had out is the fill plug. Not the one directly on top. When filling it you want the fluid to be right at the bottom of the hole. If you fill it through that top plug it would be overfull. Torque spec is 24ft/lb
Old Aug 18, 2014 | 02:52 PM
NO its not the fill plug. Ugh. The bolt between the fill and drain.
Old Aug 19, 2014 | 05:22 AM
Burnhad91's Avatar
My bad you're right! I was looking at it wrong. Maybe some trans rebuilders can chime in.
Old Aug 19, 2014 | 05:46 AM
NFSLancerRA's Avatar
Double check to make sure, but, if that is in fact the reverse idler gear mounting bolt (seems to correspond in the service manual), then the recommended torque spec for that is 57 ft-lbs. You should be able to determine this, because that particular bolt appears to have some sort of gasket on it (crush washer is what it looks like). If the bolt is not what I have described, it seems that most other bolts of the same size on that transmission are rated at 24 ft-lbs. I hope that this helps.
Old Aug 19, 2014 | 06:00 AM
Veronica's Avatar
^yeah, but... it has the magnetic tip - I would not expect that for a mounting bolt...
Old Aug 19, 2014 | 08:07 AM
I had the same thought, but the illustration in the service manual seems to suggest that the bolt in question has a magnetic tip.
Old Aug 19, 2014 | 08:30 AM
ddawg1130's Avatar
ignore that picture. he just took that from the "how to" on changing the transmission fluid. That bolt pictured with the magnetic tip is the drain bolt and is being shown for the how-to. Those aren't his pictures of his car. That's also why it's half cut off in the picture.
I admit OP should have done a better job of making the picture clear as to what he is talking about.
Old Aug 19, 2014 | 05:18 PM
ill just go with the 57 ft lbs. yea the pic is from the ho wto.
DarkSyde294
Lancer Troubleshooting
Sep 3, 2015 06:20 AM
STALIZE
Jan 26, 2014 09:22 PM
Rmeister007
Oct 13, 2011 12:05 AM
RalliartN
Apr 18, 2011 05:26 PM
simevo
Apr 12, 2004 08:47 PM
