Sponsored by:
Sponsored by: CARiD
Serious Problem on Built X !!!
Old Oct 21, 2014 | 07:11 PM
Semih321's Avatar
What's up fellas ok let me start with car
2011 X GSR
Built 2.0
Stock head
EF4
Tubular ETS Mani
Full bolt ons (Intercooler, open dump DP, hot and cold pipes etc)
ID1000CC / Walb 400
Synapse DV valve kit
ETS test pipe w/ ultimate racing Exh
Grimspeed 3 port
Stage 3 race Comp clutch kit w/ Flywheel
Short Shifter kit with all bushings
Roughly 1k miles on new setup.
28 PSI 450whp/350wtq on shell V power 93 pump ONLY
On nearly every pull car at high RPM range no matter what gear (it varies) hits an EXTREMELY violent wall. Car builds boost and runs and BOOOM hits a wall hesitates and keeps going. Extreme backfire with flames (i have multiple videos) occur. AFR sits at 11.X during WOT (depending on temp I have seen 11.3 or even 11.9 or 12.0) Boost gauge when severe hesitation occur sometimes read or 30+ (dial seems to be going past 30). ASC light comes on everytime it occurs.
Ok experienced guys will say ok this is clearly fuel cut/ boost cut due to overboost. Now let me ask you this if the MBC is set to 28...and maybe even if car spiked a little it doesnt explain the severe cut out....car never experienced this on dyno and it happened in 84 degree weather and 46. Car is due to go back in but we are scratching our heads here gentleman....WTF? Fuel pump relay?
VIDEOS OF PROBLEM
Old Oct 21, 2014 | 07:20 PM
►EvolutionX◄'s Avatar
Question: You say you are running a GRIMMSPEED 3port, but you say you are using a MBC not an EBC. Can you explain? It sounds like boost cut to me.
Old Oct 21, 2014 | 07:24 PM
Semih321's Avatar
I apologize I am running a grimspeed EBC.
Old Oct 21, 2014 | 07:28 PM
Semih321's Avatar
Video link on main post.
Old Oct 21, 2014 | 07:32 PM
Semih321's Avatar
Video on main post updated.
Old Oct 21, 2014 | 07:47 PM
Definitely looks like boost cut to me. What tune are you running? Have you checked all hoses running to and from the EBC? Also, there is a how-to check for boost leaks on this forum somewhere as well. If you weren't having problems for the last 1k miles its probably not a tune issue but rather a mechanical issue.
Old Oct 21, 2014 | 07:58 PM
Semih321's Avatar
Open source
Old Oct 21, 2014 | 08:23 PM
Only happens at wot?
Problem did not exist in previous 1k Miles?
Old Oct 22, 2014 | 08:14 AM
Semih321's Avatar
Only at WOT. And no.
Old Oct 22, 2014 | 08:42 AM
cravnpup's Avatar
Yep, boost cut. IMO, you need a better tuner as this should've been addressed. It's an easy fix though (increase boost limit and delay timer or rescale for higher limit).
Old Oct 22, 2014 | 08:52 AM
Semih321's Avatar
Raising limits doesn't address the main problem of why a car tuned for 28psi is hitting 30+ psi? The cut if anything is saving my motor.
Old Oct 22, 2014 | 09:36 AM
cravnpup's Avatar
True. I suppose I just assumed you wanted to run that boost because built motor. Again, find a tuner to get you back to your target boost. WGDC table tuning is so easy a caveman could do it..
Old Oct 23, 2014 | 08:07 AM
IRPerformance's Avatar
I say boost cut as well. The car is overboosting so the ecu cuts. Once the boost drops down a few psi the ecu allows you to resume boosting. You didn't post any boost logs but I'm betting the stock frame turbo starts running out of steam up top, which is why you don't hit the boost cut once you accelerate past it.
Old Oct 23, 2014 | 08:29 AM
ugakirk's Avatar
Who tuned this?
Old Oct 23, 2014 | 09:40 AM
andrewzaragoza's Avatar
search this forums and you will see around this time of the year alot of these threads pop up because of the colder temps. That is why i like tuning my boost based on load and not psi based.
