Sponsored by:
Sponsored by: CARiD
Motion Control Suspension (MCS) coilover?
Old Jan 22, 2017 | 07:28 PM
hispanicpanic's Avatar
Originally Posted by JJwins
Alright.... ordered!!
Jason talked me into staying with the 800/800 set-up. He was telling me something about the spring rate of the A7 tire in a 295 and that any more will essentially reduce performance of the suspension/tire. I did mention you and he said... and I paraphrase "yeah but he is running a HUGE tire!" Haha! He did say that I should be running my rear bar at the softest setting (currently on the hardest and love it) and adjust from there as needed...make sense to me. Anyway I hope he is right... we'll see. Thank for your help and input!
Well one thing is for sure, you're still starting off with an excellent baseline. Jason has a point on the spring rate of the tire.... if your springs are stiffer than the rate of your tire, then your damping will be done by the tire and not the spring/shocks! My setup isn't ideal for street tires, but i can make it work without fuss.
Old Mar 22, 2017 | 02:52 PM
JJwins's Avatar
Originally Posted by hispanicpanic
2) Rear spherical mounts are absolutely necessary if you're going over 10kg/mm springs. I tried one event with my 800 in/lb springs on the stock mounts and they were a bit squishy. Back when I first got my MCS coils, no one in the world made spherical rear mounts that would fit MCS's larger shaft diameter. MCS has since decided to offer something off the shelf, which is nice cause I ended up making my own rear top mount and of course i'm still trying to address some squeakiness in the mounts.
Hey, so I know im asking you questions on two sites but I figured this one was more appropriate since MCS is the main topic of this thread.
So I got the MCS rear mounts. Installed everything, set ride height, corner balanced and aligned. I'm getting a slight cluncking in the rear. Any thoughts on this? Do you have any? Its a litle annoying as it feels like something is gonna break. I know it's somewhat the nature of solid mounts. You said you were getting some squeaking but are you getting any cluncking?
Old Mar 22, 2017 | 03:18 PM
moladin's Avatar
Have you look into Thrust sheets that fit between the spring and spring mount?
Old Mar 22, 2017 | 04:31 PM
JJwins's Avatar
I have not but I just looked them up and I'm intrigued. If thats what will take the clunk out ill do it in a heartbeat. Sorta sucks to spend so much on a coilover only for it to clunk. :/
Old Mar 22, 2017 | 05:27 PM
Robevo RS's Avatar
Ohlins doesnt clunk . just saying
Old Mar 22, 2017 | 05:34 PM
nemsin's Avatar
My MCS 1way do not clunk. Give MCS a call, I bet they will sort you out. Also, check to make sure everything is tight.
Old Mar 22, 2017 | 06:37 PM
JJwins's Avatar
LOL!! And yours def look sexy!! Gotta give you at least that much.
Yeah I was just about to when I got back from the alignment shop but it was already past their business hours. I'll give them a call first thing tomorrow. The two times I've called they were very helpful. I'm hoping it's something I just missed during install.
Old Mar 22, 2017 | 06:39 PM
Robevo RS's Avatar
you can ride with me soon, and you will see. I am sure though the MCS you got is much better on track .
Old Mar 23, 2017 | 12:01 PM
the clunking can be from a lot of things. It all depends on where the clunking is coming from. First you have to find out exactly where it is clunking. If you have someone jump on the door sill really really hard, can you hear the clunk? If so get underneath the car and try that. Mine never clunker. Also also, are you running helper or Tender Springs?
Old Mar 24, 2017 | 01:34 PM
GoodTimes's Avatar
Just got off the phone with vorshlag and getting a quote for the 1 way to replace my old JRZ RS'1's. Seem like a quality coilover thats on pair with JRZ if not better.
Old Mar 25, 2017 | 09:44 AM
nemsin's Avatar
JRZ makes a great product but I went with MCS over JRZ largely because MCS was based in the US and Lex at MCS picked up the phone when I called and was super helpful (and obviously super knowledgeable). Try calling JRZ and see how quickly they get back to you.
Old Mar 25, 2017 | 10:29 AM
GoodTimes's Avatar
Never really had a problem getting a hold with JRZ. Found a good dealer in the states that rebuilds and re-valves. The RS1's are "High maintenance" thats all i will say. But they have been great over the years.
I'm gong to pull the trigger on Monday. MCS 1 Way. 700lbs Hypercoil springs square. Helper springs. Vorslag camber plates. MCS rear top hats.
I'm on RE71R. You guys think 700lbs is to stiff for "street tires". I'm running 572lbs swifts on the JRZ now.
Thanks for any input
Old Mar 25, 2017 | 01:36 PM
nemsin's Avatar
I run 600# front /650# rear. On RE71r tires and have never felt like I needed stiffer spings. But my car only weighs ~2800lbs.
Also, get the vorhlag camber plates if you do not already have a set, they are worth it. Positive caster ftw.
Old Mar 25, 2017 | 01:53 PM
GoodTimes's Avatar
Ha. My car weighs ~ 500lbs more, think i will stay with the 700#.
There camber plates are on the list
Old Apr 4, 2017 | 09:45 AM
JJwins's Avatar
Well I'm glad to report that all the clunking has magically disappeared... well sorta. Though its hard to imagine that this was the cause I did find one nut on the rear lower control arm that was a little loose. Also, I am still getting a slight clunk over larger bumps/potholes but it sounds like the helper spring collapsing/compressing - I can live with that. All in all after 3 autoXes on this suspension I am very pleased and thoroughly impressed!
Now I just gotta figure out how to adjust compression and rebound properly.
vitamin ek2
Oct 29, 2013 07:59 PM
vitamin ek2
Aug 29, 2013 05:25 AM
Most-Wanted
19
Sep 27, 2008 03:28 PM
project_wonderb
Jan 30, 2006 04:41 AM
