Sponsored by:
Sponsored by: CARiD
Vibration at higher speed
Old Apr 7, 2015 | 03:38 PM
jayyyw's Avatar
If swapping wheels helps, take yours to Discount Tire and have them "Road Force" balance your wheels. This will tell you if you have a bent wheel, bad tire, or bad balance.
Old Apr 8, 2015 | 05:47 AM
AlexDRS94's Avatar
I'm going to switch them today. Unfortunately, there's no Discount Tire within 100 miles of my zip code
Old Apr 8, 2015 | 05:59 AM
the 10th 1dr's Avatar
My guess would be similar to the other.... Rim issue... Tire issue.... Or wheel weight issue.... Let us know how it turns out.
Old Apr 9, 2015 | 01:16 AM
Evodetailer123's Avatar
I would try a rotation using the x pattern, if that doesn't do it inspect all tires very closely, if you Dont find anything, just go to a discount tire make sure all wheels are balanced and have them tested
Old Apr 9, 2015 | 11:19 PM
jayyyw's Avatar
Firestone also has a balancer with "Road Force" balancing. If not, call your bigger tire service shops and see if they offer than service.
Old Apr 14, 2015 | 04:37 AM
AlexDRS94's Avatar
Ok guys, so I've tried all of your suggestions and it definitely isn't a wheel issue. So its a either an axle or bearing problem
LSs1Power
May 31, 2017 07:47 PM
Nelson999
34
May 12, 2014 06:50 PM
elhuberto
Sep 13, 2013 04:45 PM
samurat
Lancer Engine Tech
Jun 24, 2008 05:08 PM
