Sponsored by:
Sponsored by: CARiD
Is the SST on Evo X reliable
Old Apr 4, 2016 | 09:50 AM
  #46
Rel0ad_RaChet's Avatar
Originally Posted by jakeleclair2000
If you want long life out of the sst do the following
1. Fluid and Filter change every 15k miles. More frequent if you track the car.
2. Stay under 350 wheel torque when on stock clutches
3. Get a Dodson Sump. pushing the sst before its up to operating temp is very bad.
4. When/if you get the car tuned, make damn sure you're tuner knows what they are doing. Contact eric @ Kozmic in houston,tx. They are the sst kings.
5. Learn how to properly operate the SST. It is a twin clutch automated manual, not a typical torque converter automatic, nor is it a cvt, and should not be driven as one.
6. ????
7. Profit
I do not understand how to stay below 350 Nm when the car is 370 stock I do not understand something maybe ?
Old Apr 4, 2016 | 10:43 AM
  #47
shekaar's Avatar
370 nm is ~270 lb ft. You want to keep it under 350 lb ft of torque, ~475 nm.
Old Apr 4, 2016 | 04:11 PM
  #48
TurboTJ's Avatar
Originally Posted by Napalm_Enema
When at a stoplight if you leave it in gear, the clutches heat up because they are basically sitting there holding tension. Get in the habit of putting the car in neutral at stoplights and driving in S-Sport manual mode to prolong your transmission / clutches.
I don't think this is true. Try this - When on an incline (facing uphill), barely let off the brakes. You will notice that the car rolls backwards. This is because the SST hasn't engaged the clutches yet since it believes the brakes are still holding the car stopped. A tradition automatic won't do this.
Old Apr 5, 2016 | 07:23 AM
  #49
jakeleclair2000's Avatar
Its 100% true.
Go for a drive and log clutch pressures and you can see for yourself.
Old Apr 7, 2016 | 06:54 AM
  #50
hispanicpanic's Avatar
I've put about 2 years of severe track use on the SST and it's still ticking. 310 hp and 320 tq on Kozmic's mustang dyno. Stock turbo /w boltons. Just keep your oil fresh and you're fine.
For DD/track use stick to 10k oil change intervals. For pure track use, i'd swap every 6-8 events. 20k if its pure DD. 30k is recommended but i've found shifting gets a little notchy towards the end of life of the oil and a fresh oil change gets it smooth as butter again.
Old Apr 7, 2016 | 07:10 AM
  #51
BlueBlurSTi's Avatar
That's very hard on the SST
Old Feb 9, 2018 | 03:18 AM
  #52
DRAGHICI's Avatar
Is it wrong respinding to a thread from a few years back that’s still relevant?
I came from a 8 MR, I just want to point out that im going towards 175000 miles in my DD 2010 MR that i bought brand new.
Im tuned with bolton’s around 350whp since 60000 miles.
I drove/drive the car in normal and sport 99.99% of the time, i never beat on her except some wot once in a while on the highway, SS once in a blue moon.
My first sst oil change was at 56000 miles and second at 100000, no sst oil change since then. She still runs great as my DD Beast!
Most reliable car i ever had!
LVSBB6
For Sale - Part Outs
Mar 15, 2015 05:34 PM
moody91180
Mitsubishi TC-SST Discussion
Oct 11, 2014 06:22 PM
SSP Jeremy
EvoX 'For Sale' Engine Internals and Drivetrain
35
Aug 13, 2013 08:42 AM
SmurfZilla
13
Oct 6, 2012 01:29 PM
nongan
Future Lancer / Evo Models
40
Aug 23, 2007 04:10 AM
