Sponsored by:
Sponsored by: CARiD
EVO X with ETS TBE system, does stock test pipe fit w/ it?
Old Jun 17, 2015 | 02:28 PM
ezzey's Avatar
Trying to figure this out for a friend.
evo x gsr 2014 ets full turbo back exhaust with recirc dp
does this setup allow to change out the test pipe with stock test pipe? or are they different lengths, etc?
Thanks.
Old Jun 17, 2015 | 02:33 PM
hoobastnk90's Avatar
What do you mean stock test pipe? Do you mean swapping the stock cat back into it?
Old Jun 18, 2015 | 02:36 PM
ezzey's Avatar
Yes, sorry didnt make myself clear.
Can the stock cat be swapped into place of the test pipe for that exhaust system.
Old Jun 18, 2015 | 02:41 PM
Yes it can.
Old Jun 18, 2015 | 02:55 PM
evoxsteez's Avatar
It might leak unless you use proper gaskets. Stock cat is 2.5 inches and the ETS pieces are 3 inches.
Old Jun 18, 2015 | 03:24 PM
ezzey's Avatar
Again, i wasn't being specific my apologies. Is the outer dimensions the same though? Flange rotation the same, and length from end to end. And yes, 2.5 to 3" wouldn't work.
Old Jun 18, 2015 | 05:01 PM
JF450's Avatar
*Note: If using a stock catalytic converter select the adapter flange in the drop downs below.
when ordering the catback from the website it has an adapter flange option for 15$ to fit it to the stock cat.
Old Jun 18, 2015 | 07:53 PM
ezzey's Avatar
Awesome, thank you.
03redtype-s
Dec 26, 2016 07:49 AM
IspyEvo
Jun 25, 2010 02:17 AM
Boost3dxEvO
53
Dec 9, 2007 09:35 AM
Gruppe-S
21
May 1, 2007 01:42 PM
