Sponsored by:
Sponsored by: CARiD
HELP!! MAP/Walbro E-85 line will not fit onto fuel pump
Old Jun 20, 2015 | 06:06 PM
VADER X's Avatar
HELP!! MAP/Walbro E-85 line will not fit onto fuel pump-image.jpg
In need of some advise from those with this kit (Walbro 450 lph fuel pump with MAPs adapter kit and E-85 safe fuel line (clear/white flexible hose). How were you able to fit the fuel line over the barbs on the fuel pump? No matter how hard I try I am unsuccessful at getting it over the first barb.
I've read through the threads of those who've installed this kit and none seem to have the problem I am. I stopped by the local NAPA and they suggested boiling the ends of the fuel line in water to expand it first. Before going that route I was hoping to get some insite from those who've done it. Thanks
*EDIT*
Placing the line in boiling water didn't do a thing to help. I let it sit in boiling water for 30-45 seconds and it had absolutely no effect
Old Jun 22, 2015 | 08:46 AM
momostallion's Avatar
Originally Posted by VADER X
Attachment 243045
*EDIT*
you can try this, use a bit of oil on the barbs.
http://ls1tech.com/forums/fueling-in...l#post15193388
OR if that fails, you can dremmel down the barbs a bit but try to leave at least a small lip. plug the hole to make sure you don't get debris in your pump.
Old Jun 22, 2015 | 12:20 PM
theblackbeast11's Avatar
try heating it up with a heat gun and see if it slips over it idk just a thought
Old Jun 22, 2015 | 01:47 PM
hoobastnk90's Avatar
Why not just call MAP and ask them ? They usually provide pretty good support.
Old Jun 23, 2015 | 08:57 AM
ogrenator's Avatar
I used a heatgun to soften it up a bit...maybe keep it in hot water longer...
Old Jun 28, 2015 | 03:46 PM
Blue_CobaltSS's Avatar
I like the MAP idea. Should be an explination for this
Old Jun 30, 2015 | 06:21 PM
Evodetailer123's Avatar
I did this last week. You have to use a heat gun and heat up that end. Should work.
Old Jul 1, 2015 | 07:25 PM
sfcmotorsports's Avatar
Warm it with the heat gun and it will go on with some extra elbow grease!
okevolutionVIII
Nov 26, 2012 11:19 AM
KenTen
Northeast Region
Jun 19, 2012 03:01 PM
jfeo
Mar 5, 2012 01:37 PM
Carloverx
14
Dec 22, 2011 01:00 PM
