Sponsored by:
Sponsored by: CARiD
Evo X brake bleeding
Old Feb 4, 2016 | 12:12 PM
RazorLab's Avatar
I use the motive at 20-23psi.
5psi would not work very well and you would have to keep pumping it up which would kind of defeat the purpose.
Old Feb 4, 2016 | 12:16 PM
hoobastnk90's Avatar
Ya that was pretty much my logic as well.
Old Feb 4, 2016 | 01:07 PM
e_kobz's Avatar
I've never had an issue with mine between 5 and 10psi
Old Feb 4, 2016 | 01:18 PM
hmm well I usually do mine before or between track day weekends so maybe im trying to move more fluid out then you are so I like to use the higher psi!
Old Feb 8, 2016 | 10:24 PM
patience's Avatar
I'm at 20 psi too on my Motive. Just gets it done faster. There is some logic that the higher pressure moves bubbles out of the system better, but if you're not ever draining it dry, it won't matter. If you ever do swap flex lines and have the system dry, don't let the whole system empty, because bleeding the ABS pump is a pain and a half.
sna08
21
Mar 26, 2012 10:32 PM
DaWorstPlaya
Oct 21, 2008 09:47 AM
ev8sive
11
Feb 12, 2005 02:02 PM
EvoNick
May 26, 2003 06:42 PM
