Sponsored by:
Sponsored by: CARiD
who does oil changes > 3k intervals?
Old Dec 4, 2018 | 05:13 PM
  #46
DeweyD's Avatar
I usually start paying attention at 3k (buy oil and filter if needed) and then don't actually get around to changing it until 4-5k. If you aren't revving the crap out of it I'm not sure why you would need to change it at 3k, not if you are using a high quality synthetic.
Old Jan 3, 2019 | 03:46 PM
  #47
CanEvoX's Avatar
Originally Posted by CaptainCrunch
What about cars more comparable, like the CLA45 AMG? 2.0L turbo, making bigger power. Long intervals for them.
It has nothing to do with the size of the engine, etc. It's the machining precision. Oil can withstand 9k miles before you need to change it, that's what Mobil 1 states on the jug.
The real reason to follow the manual intervals is because every engine is built differently and around 3k miles oil is contaminated with 3% gas from blow by, whic his not the case on BMW and AMG due to tighter seals or whatever else their engine design is the culprit.
So mitsubishi engines get oil dirty. Period. No knowledgeable person would tell you "modern cars" and "syntetic oil" in one phrase.
So stick to schedule.
Old Jan 3, 2019 | 03:47 PM
  #48
CanEvoX's Avatar
Same as above - you can run unicorn tears there but if your oil contains 3% gas it's lubricating properties are severely diminished.
Old Jan 7, 2019 | 01:01 PM
  #49
pikwit's Avatar
That's a perfect interval but I'd swap it out if I was going to HPDE or autox or had let my car sit for more than a month with a lot of temperature fluctuations.
tcl0817
Jan 30, 2018 08:24 PM
bobby.is.rad
Apr 6, 2012 09:19 AM
evo_rc
Dec 19, 2007 04:43 PM
Vroompsh
Apr 14, 2004 10:45 AM
moncef
Mar 16, 2004 01:28 PM
