Sponsored by:
Sponsored by: CARiD
Evo x 30k service!
Old Apr 6, 2016 | 08:53 AM
ohYouEvo's Avatar
Evo x 30k service!
Hey guys!
Just wondering if any of you have done their 30K service on your evo's? What is the most important stuff to buy and change. I know if I take it to the dealer they will make a hole in my wallet.. Does anyone have done their 30k service and what they recommend to do or buy?
Thanks
Old Apr 6, 2016 | 09:11 AM
Epyon's Avatar
Well, there's already a thread about the 15k service. And the 30k will be the same stuff plus a little extra. I believe there was some things they told the guy to wait til 30k to get done so you might want to read through this.
https://www.evolutionm.net/forums/ev...es-inside.html
Old Apr 6, 2016 | 10:07 AM
.M.'s Avatar
.M.
Yup. Plenty of info out there. Just do a search. You should change all your fluids... Trans, transfer and rear diff.
Old Apr 6, 2016 | 10:25 AM
diz_'s Avatar
Basically going to be a full drivetrain flush. After I hit 30k my clutch was a little beat from all of the highway pulls on power levels well over stock. If any extra maintenance is needed have them do it while things are apart. Had a shop that wasn't even going to charge labor or anything on the fluids since the tranny was getting popped open anyways. MAP sells a complete drivetrain service kit for when you hit the 30k mark.
Old Apr 6, 2016 | 11:15 AM
ohYouEvo's Avatar
Can you be more specific as of all fluids? Like do I just go to the dealer and ask for all fluids for Evo X service?
Old Apr 6, 2016 | 12:16 PM
Epyon's Avatar
Just go there and tell them you need a 30k service, they will be able to give you a list of what it recommended by mitsu.
Old Apr 6, 2016 | 12:40 PM
ohYouEvo's Avatar
Thanks!
Old Apr 6, 2016 | 01:58 PM
.M.'s Avatar
.M.
Transfer and Rear Diff:
DiaQueen GL5 LSD Gear Oil. 2qts. of GL5. The rear differential holds .55L and the transfer case requires .6L.
Trans (GSR):
Factory - DiaQueen Multi Gear Oil.
Alternative - Redline MT85, Redline cocktail (search for info), Amsoil (again, search). 3qts. Holds about 2.6qts.
More info here:
http://www.maperformance.com/product...FYQ8gQodqJsEkg
Old Apr 6, 2016 | 02:23 PM
ohYouEvo's Avatar
Trans (GSR):
More info here:
Thanks for the help!
miss_vtec
Northwest Region
35
Jul 19, 2010 10:06 AM
V8 HUNTR
Mid-Atlantic Region
Apr 18, 2005 06:44 PM
NYREDEVO
Feb 1, 2005 06:49 AM
Deltarider99
Dec 6, 2004 08:57 AM
