Sponsored by:
Sponsored by: CARiD
Bad Turbo
Old Oct 19, 2016 | 04:53 PM
Fuego's Avatar
Bad Turbo
i think my OEM evo x turbo is bad and will probably replace it for now with an Another one. Would I need to get retuned?
Old Oct 20, 2016 | 08:36 AM
Veronica's Avatar
No.
Why do you think it is bad?
Old Oct 20, 2016 | 08:40 AM
Fuego's Avatar
I have a whistle sound that seems to be coming from it. Sounds like a bearing whistle sound and it only sounds when i'm giving the car gas. i'm heading to the shop in a few mins so that I can inspect it and check for vacuum and tube leaks. Also to do service on the car, maybe some fresh oil would help, it's due for service.
Old Oct 20, 2016 | 08:43 AM
Fuego's Avatar
Any other way to test out the turbo besides taking it out?
Old Oct 20, 2016 | 09:36 AM
shekaar's Avatar
Take the intake piping off, reach in there and check for shaft play. Easy way to see if there's anything obviously wrong with it.
Old Oct 20, 2016 | 10:55 AM
Napalm_Enema's Avatar
whistling could be a boost leak I'd rule that out before pricing out turbos.
Old Oct 20, 2016 | 05:21 PM
Fuego's Avatar
This is how my turbo is spinning. Sorry I tried my best on this video. Will try to get one of the sound also!
Old Oct 20, 2016 | 06:31 PM
Fuego's Avatar
Sounds identical to this
Old Oct 20, 2016 | 09:38 PM
4b11slayer's Avatar
I dont hear anything. And the turbo looks good. You would see scratch marls on compressor housing from wheel hitting. And or chipped fins.
Old Oct 21, 2016 | 05:34 AM
Also you would see 'shaft play' that is where the center moves around side to side, what the fins are spinning on.
A lot of people with a similar whistling noise have found it to be coming from the drivers side window:
https://www.evolutionm.net/forums/ev...le-45-mph.html
http://www.evoxforums.com/forums/sho...police+whistle
There are a few other threads but most have had the dealerships replace the drivers side mirror, if that is your issue.
Old Oct 21, 2016 | 06:55 AM
Fuego's Avatar
This is what I took out yesterday from the Transfer Case. The most I ever seen and I service it every 10k-15k with Dia queen LSD oil. Some other people said it has a whine sound also.
Going to get a video of my car making the sound today.
So Turbo is good and I could not find any vacuum of boot leaks.
It don't seem like the mirror issue.
Old Oct 21, 2016 | 08:02 AM
Fuego's Avatar
Sounds like a woooooooo sound in the video. In the car it seems to have a slightly higher pitch and it only happens when I give the car gas. If I let go of the gas pedal the. U don't hear it.
Old Oct 21, 2016 | 09:15 AM
hoobastnk90's Avatar
That looks like a lot of metal for it being changed that frequently.
Old Oct 21, 2016 | 09:45 AM
LetsGetThisDone's Avatar
Yeah. The tcase shouldn't make that much metal.
Old Oct 21, 2016 | 01:18 PM
Fuego's Avatar
I agree. Looking to see how to really check to see if that's the issue. I know jacks repairs them but i want to know all my options at this point :-((
