Sponsored by:
Sponsored by: CARiD
Modification
Old Dec 8, 2016 | 10:03 AM
LSB's Avatar
LSB
Modification
I own a 2013 Evo GSR, it was my lease and I just purchased the car. So I got another 5 years of payments, anyways, I want to do mods for it like, exhaust, exhaust manifold, intake, and E85, lowering springs. And I'm worried that I will have problems with the check engine light and blowing the motor and Trans. If I do any of these mods, will my above issues come true? I'm not a new driver or a real young driver. I know how to drive, I wouldn't push it every single time I'm in it. Trying to avoid having to buy a $18,000 trans. So any info would be helpful, thanks.
Old Dec 8, 2016 | 12:18 PM
splattj's Avatar
Done well / correctly nothing you're thinking of doing will cause issues. The trans for a GSR is more like $1,800 to rebuild than $18k. You can get up to about 400 lb-ft before you're going to have to start worrying. Just do some searches on the forums to look at options for power mods. Lot's of proven combinations.
Old Dec 8, 2016 | 01:47 PM
ChipperEvo's Avatar
There are a ton of threads over this very topic.
Exhaust (w Test pipe/HFC)
3 port boost controller
Injectors (for E85)
fuel pump (for E85)
Tune
Intake (optional)
Downpipe (optional)
BOV (optional)
Hard IC piping (optional even though an Upper pipe is recommend replace the rubber that flexes).
Old Dec 8, 2016 | 02:20 PM
LSB's Avatar
LSB
Thanks it is much appreciated.
Old Dec 8, 2016 | 07:02 PM
4b11slayer's Avatar
Blowing up your engine is always a possibility In this game.
Old Dec 8, 2016 | 08:26 PM
Napalm_Enema's Avatar
Just contact 5150 in your area, tell them your goals, and either modify your car or leave it 100% stock and enjoy it as it sits. You may be sick of the car at the end of your lease, so why modify at all really? Just put in a drop in filter and call it a day. Car is pretty quick stock.
If you just have to modify it, take it to a pro shop that knows the EVO so you don't blow it up, that simple. 5150 is in your area and are really highly regarded in the EVO scene.
Old Dec 8, 2016 | 11:00 PM
LSB's Avatar
LSB
​​​​​​​Thanks so much
Old Dec 8, 2016 | 11:24 PM
roidz3's Avatar
Definitely talk to 5150 and skip the exhaust manifold with the stock turbo!
Old Dec 9, 2016 | 05:56 AM
ugakirk's Avatar
Yea if you're really going E85, you may as well upgrade the turbo IMO.. The stock turbo can run out of room pretty quick on the X.
But yea, like everyone said, call a good shop like 5150 and get some quotes.
The engine can always be blown, even stock.. It mainly depends on the way you're going to drive it and the tune that you get. Just don't drive the car like a crazy person.. But the Evo can def take the mods that you want.
Old Dec 9, 2016 | 06:32 AM
Bhsj13's Avatar
if you are that worried, dont mod it.
suave3747
Dec 23, 2002 08:48 PM
ishi
Site Feedback / Suggestions
Oct 8, 2002 10:21 AM
milesaway
Aug 4, 2002 11:28 AM
