Sponsored by:
Sponsored by: CARiD
Evo X weird sound/whine
Old Jan 10, 2017 | 11:41 AM
JrEvoXnitez's Avatar
2011 evo x GSR. This sound does not stop. Its a whine. While in gear or at idle. sometimes it stops. It sounds most the time. 98% of the time. I put a new engine into the car. But this sound started happening after i changed the Alternator. If anyone has encountered this problem please help. Its driving me crazy.
Heres a link.
Old Jan 10, 2017 | 11:48 AM
splattj's Avatar
If it started after you changed the alternator, I'm going to go with bad bearing in the alternator or possibly one of the two idler pulleys or the tensioner pulley....
Old Jan 10, 2017 | 12:45 PM
checked my pulleys and changed my tensioner. Still nothing
Old Jan 10, 2017 | 02:33 PM
splattj's Avatar
Well, try running the car with the serp belt off for a few seconds. It'll be fine without the alternator and waterpump (and PS & A/C) for just a few seconds. If it's quiet, I'd say you got a bad replacement alternator. It happens, even with brand new parts.
Old Jan 11, 2017 | 07:17 AM
jakgal04's Avatar
That sounds like an alternator issue. Like splattj mentioned, run the car with the belt off and see if the sound persists. Or if you pick up a cheapo mechanics stethoscope you can test the different areas.
Old Jan 11, 2017 | 07:40 AM
six40's Avatar
An even cheaper alternative is to use a piece of rubber hose. Before you laugh, it works... lol
Old Jan 11, 2017 | 08:09 AM
jakgal04's Avatar
Thats actually a genius idea lol I'll have to compare the two and see if I wasted $5.88
Old Jan 11, 2017 | 08:46 AM
six40's Avatar
Yeah! I learned that trick from Marco @ Magnus when I was there a few years ago and he had my old red DSM on the dyno to tune it. He used a rubber hose to pin down a vacuum leak which was caused by a torn lower injector seal. I've used that method since, works well
AustEvo
May 4, 2018 03:02 PM
deeman101
16
Dec 2, 2014 09:16 PM
xSoLD3Rv
Feb 17, 2013 03:26 AM
JKD
Aug 29, 2009 05:20 PM
TeStUdO
14
Jun 30, 2006 08:11 AM
