Evo x MR tuning
You can get a built trans with 10 plate clutch and Dodson sump from Kozmic for ~$7k and it even comes filled with fluid and teach in completed. Just install and go. (source- I've done two for clients). If you go by book time, you'll get billed 9.8hrs at shop rate. Most Evo shops do a flat rate on trans/clutch installs though so if you pay more than $1k to install it, you're getting hosed.
It is expensive. BUT, consider a built 5 speed with all the options for a GSR is like $3k+ from like TRE or similar, and a good twin plate clutch is close to $2k, the price difference isn't "insane" per se.
