Sponsored by:
Sponsored by: CARiD
Should I replace this tire as a set?
Old Jun 17, 2017 | 11:16 AM
fafaforza's Avatar
So I got a puncture. I have stock tires, and only 6500 miles on them and the car. Got the car new in October. Do you guys think I would want to replace this one as a set of two? Or could I get away with replacing just this one?
This is the tread wear. The outside of the wheel is on the right. I see a bit more wear there than the inside. Is that the crappy factory alignment I'm seeing?
And anyone think this could be patched/plugged?
Old Jun 17, 2017 | 12:07 PM
Napalm_Enema's Avatar
That puncture looks fixable. Take it to Discount tire and get it patched.
Old Jun 17, 2017 | 01:55 PM
4G63_EVO's Avatar
I work at just tires and we would not fix it from the looks of it, depends what the inside looks like. Gash usually is a deal breaker, May be able to get away with multiple plugs but thats just dumb.
Old Jun 17, 2017 | 02:34 PM
fafaforza's Avatar
It was some sort of a flattened cylinder metal, with a plastic straw on the inside and some dried up stuff inside. Maybe some home building caulking gun.
But it didn't seem to make a big hole. I could barely fit a plug file through it, so I decided to plug it. I'll put 50-60psi in it and leave it overnight on my balcony, see if it holds air.
I definitely wouldn't double up on plugs. But I've used them many times on my motorcycles without any failure. Will see how it works on the car tire.
But how does my wear look? The outside seems a lot more worn than the inside, which looks almost new. Is it the alignment?
Old Jun 17, 2017 | 03:17 PM
4G63_EVO's Avatar
More than likely yes my friend had the same thing on his Evo 10 bad alignment from Factory
Old Jun 18, 2017 | 05:42 AM
lancer man's Avatar
thread on tyres look good
Old Jun 23, 2017 | 12:26 PM
BStalzer12's Avatar
Just replace the one if your just doing it for the damage
Old Jun 23, 2017 | 01:28 PM
4G63_EVO's Avatar
not a good idea for the Diff
Old Jun 23, 2017 | 01:37 PM
splattj's Avatar
Tire Rack can shave a replacement down to the same tread depth (as can some local shops)
Otherwise it's all four
Old Jun 23, 2017 | 01:42 PM
4G63_EVO's Avatar
Wow this is awesome!
Old Jun 23, 2017 | 01:59 PM
LetsGetThisDone's Avatar
A new oem tire is $400 + shaving is $30, plus shipping and install. Said and done, you're close to $500. Just get a new set of tires...
Cotton plugs don't work in radial tires. They're for bias ply tires. I would not run that tire with the cotton plug in it.
Rob_GPT
Nov 8, 2008 09:11 PM
Neal@tirerack
15
Oct 9, 2007 01:59 PM
watchout
Oct 2, 2004 01:30 PM
AbusiveWombat
Feb 17, 2004 11:16 AM
