Sponsored by:
Sponsored by: CARiD
maintenance help for a noob!
Old Apr 5, 2018 | 07:35 PM
CaptainCrunch's Avatar
Originally Posted by DeweyD
Let me be more clear. If your Evo has an AYC rear diff (all North American Evo X's)...
When you do fluid maintenance on the rear diff, you should have opened TWO drain plugs and TWO fill plugs and used TWO different types of fluid.
i just did this on an Evo X and will being doing it on my X again here soon. If there are no good youtubes on the process I will try to document mine for posterity.
A vid would be amazing. Thanks.
Old Apr 6, 2018 | 08:24 AM
DeweyD's Avatar
Originally Posted by CaptainCrunch
Meh don't care about all that. So to clarify, do the SP3 fluid that is pictured above.. and the procedure is simple as what the directions say? Flush and fill, basically? Thanks a ton.
Yeah it's as simple as that. The rear diff is divided into two sections. The gear section that takes the LSD oil and the wet clutch section that takes ATF.
The whole AYC/ACD hydraulic pressure actuated section is separate and pressurized. It has bleed screws up near the transfer case area and has the reservoir in the trunk and the pump/accumulator behind the rear passenger tire. This is the ATF part that you DON'T touch. You would have to be doing something very wrong to tap into that.
if you follow the service manual on the rear diff service then you are doing it right.
Old Apr 6, 2018 | 09:20 AM
AWESOME! Thank you! Was pretty daunting stuff til now. Appreciate it! I thought the tank in the trunk was for the ATF oil I was changing underneath right next to the LSD oil. Thanks for clarifying that for me too!
Sivtec00
Evo X How Tos / Installations
Jun 12, 2014 07:42 AM
leemaster
10
Mar 27, 2014 11:18 AM
urslo4n8
Mar 23, 2008 08:27 AM
SpeedJunkyz
Jan 21, 2008 04:24 PM
