Sponsored by:
Sponsored by: CARiD
What's wrong with my car?
Old Mar 5, 2018 | 08:48 PM
alby988's Avatar
Hey guys,
I was merging from an on-ramp today and I went WOT in 3rd gear when all of a sudden it felt like the car had a hiccup and it bucked. I tried going full throttle again in 3rd gear and everything was normal. I tried a third time and it happened again. From a stop I did a 1-3 pull and it was alright. There is no CEL and I'm confused as to what it could be.
Any help would be appreciated! Below are the specs for my car.
2010 GSR 115,000 miles
hks catback
stock clutch replaced at 105,000 miles with oem stock stock clutch
Old Mar 6, 2018 | 03:33 AM
DRAGHICI's Avatar
Check the sprkplug gaps and or make sure all your hoses are tight too
Old Mar 6, 2018 | 05:23 AM
W0LF's Avatar
As previously mentioned, you could check/replace the spark plugs and test for boost leaks. You've got a really high post count so I'd imagine you've been here awhile and are familiar with common problems such as the FPR hose popping off and the Fuel Pump relay. If you are sure there's no issues with anything of the sort, then it could b be something simple like hitting Boost cut due to overboosting in cold weather. I'd recommend doing datalogs for review and end it right after the bucking occurs. Take note of the speed it happens in order to better pinpoint the problem area.
Old Mar 6, 2018 | 07:12 AM
alby988's Avatar
i checked the hoses as soon as i got home and they were good. i'll check the park plugs and look for a boost leak.
thanks guys!
Old Mar 6, 2018 | 01:06 PM
Scootypuff86's Avatar
Check the fuel pump relay, that is what my car was doing and it ended up being that. I even had the updated ones from SSP installed, however they where about 4 or 5 years old at that point.
Old Mar 8, 2018 | 06:23 AM
six40's Avatar
Yep definitely check the fuel pump relay. Not saying that's the end-all problem for these cars, but it could be it.
Old Mar 15, 2018 | 02:52 PM
Tero's Avatar
Sounds like plugs. When did you last change them?
Old Mar 16, 2018 | 11:05 AM
DeweyD's Avatar
Agreed, could be misfire. Pulling plugs to check is fairly easy.
Old Mar 16, 2018 | 11:11 AM
DeweyD's Avatar
https://m.youtube.com/watch?v=-X7raAXRU-0
Here is what mine did when it misfired. Got progressively worse. Drove fine normally but anything beyond part throttle would cut out. Turns out plug #4 was destroyed, perhaps from detonation/bad gas. Probably good to replace plugs regularly too.
Spooldyou
65
Nov 10, 2006 07:18 PM
Blings
Canadian Forum
12
May 20, 2004 08:35 PM
