WTF Flexfuel kit Reading Ethanol Content level
Okay i have wtf flex kit install but im trying to read my ethanol content from torque pro on my android but i can't get a reading. My tuner is able to see the reading from his laptop. I used the correct pid. Anyone knows how to do it exactly or know why is my not working or does it even work for anyone? There was a guide that i tried but still no luck. please help i literally got this kit because of that feature. I already told them basically they said im out of luck unfortunately.
Yeah it works with the laptop and thats what im thinking to but i put everything correctly though. I wonder if it’s even working for anyone
I've tried searching for a different PID to use but nothing I've found has worked. I haven't bothered with it since, as I didn't really need to see ethanol % without my laptop, but it'd be nice to get it working...
The PID on the stock ECU is for the the fuel tank pressure sensor. So, in the torque app the calculation is for that, and it's the wrong conversion calculation for the ECA output voltage and finding the ethanol content to display on the screen.
Just like when an OMNI 4bar map is used, you have to change the calc in evoscan to get a proper number. I imagine this issue is due to hat.
Not sure on the Haltec though.
Hey idk if this is of any use for you but I figured out how to get Torque to display my ethanol content. Maybe you can try this PID.
PID: 01 52
Min: 0
Max: 100
Scale: x1
Equation: A
This works with my Haltech which uses standard OBDII so might not work with your setup, but just figured I'd share.
PID: 01 52
Min: 0
Max: 100
Scale: x1
Equation: A
