Sponsored by:
Sponsored by: CARiD
Whine noise on left turns
Old Oct 1, 2019 | 07:10 AM
WW13GSR's Avatar
50k miles on the car, 2013 GSR. I'm hearing a loud whine on left turns, mainly on cold starts. For example, turn on the car in the morning and pull out of driveway, first left turn I make I hear a very prominent whine on the turn. Each turn after it gets quieter and is pretty much eliminated when warmed up after a few turns. Power steering fluid isn't low, and there are no noises whatsoever on right turns.
I'll be changing my transfer case fluid this weekend and will have the car jacked up, so I'm going to check it out and am wondering what I should be looking for/what could be the culprit?
Appreciate any insight
Old Oct 1, 2019 | 11:29 AM
Napalm_Enema's Avatar
Have you checked the fluid level in your AYC pump? It's in teh trunk
Old Oct 1, 2019 | 12:19 PM
WW13GSR's Avatar
Haven't checked but will tonight. I'm thinking it's has to be an issue with the components on the front left side though, as if fluid was low I imagine it would affect more than only left turns
Old Oct 1, 2019 | 12:59 PM
lol you'd be surprised but hopefully if not what I suggested something simple!
Old Oct 1, 2019 | 01:20 PM
WW13GSR's Avatar
Hey if it's something as easy as topping off fluids I'll be ecstatic lol..
Question though, if I am low on AYC pump fluid will I need to bleed the system when topping off? Or is that only on complete fluid changes
Old Oct 1, 2019 | 04:58 PM
WW13GSR's Avatar
So the fluid level is perfect. It's at the Max line when cold and Min when warm...
Old Oct 3, 2019 | 10:54 AM
ugakirk's Avatar
I think it has to do with the P/S.
Is it only left turns?
Old Oct 3, 2019 | 12:59 PM
WW13GSR's Avatar
Yes, only on left turns.
Is there anything I should specifically be looking for to diagnose this?
Old Oct 4, 2019 | 05:25 AM
Really feels like you need to swap your power steering pump with a known good one and see if the sound goes away. Whining noises I associate with motors / pumps.
Old Oct 4, 2019 | 06:29 AM
WW13GSR's Avatar
Yikes, hope I don't need a new pump as they're $900+. I'll start off by changing the fluid and hope that works..
Old Oct 4, 2019 | 08:13 AM
ugakirk's Avatar
Yea hopefully changing the fluid will help out. It can't hurt.
As far as the pump goes, I would try and see if you can find a good used one. It definitely could be the pump considering its a whine and goes away at different temps.
Old Jul 1, 2021 | 05:14 PM
ghost1face's Avatar
I'm starting to see the same thing, thought I was the only one until I found this. What did it turn out to be?
Old Jul 1, 2021 | 05:21 PM
jrsimon27's Avatar
You need to change out the steering wheel fluid this happened to to my car and it was the fix.
julian9019
Sep 22, 2016 11:55 AM
makulitz
Mar 11, 2013 12:34 PM
track attack 01
Apr 21, 2012 02:24 PM
dangle
15
Feb 5, 2012 10:18 PM
Satori
Feb 8, 2004 07:22 PM
