Sponsored by:
Sponsored by: CARiD
EVO X Rise form the ashes.
Old May 28, 2020 | 07:55 AM
RazorLab's Avatar
Are you sure it's rod knock? The 4b11 can be pretty loud on cold start after sitting for months.
Old May 28, 2020 | 08:08 AM
kernelh's Avatar
@razorlab
It was really loud and def sounded like it was.
You think I should put piping and lines(vacuum) back together, check/change oil to see if still sounds like that? I just dont want to cause more damage(if there is any)
Im assuming here, but since the lines and piping are disconnected will cause the car to start and die immediately right? No CEL codes popping up, I will try and get a video snippet so everyone can have a better idea of what I mean. But what happens is the car starts goes to I want to say 1500RPM for s split second then dies. If I do this consistently you get the rich smell of gas. Which tells me its not getting enough air or the maf thinks its getting too much air.
Old May 28, 2020 | 10:07 AM
RazorLab's Avatar
If the IC pipes aren't installed the car is getting totally different air than the MAF is measuring. This is one way the car wouldn't run correctly.
I would pull the oil filter and cut it open and see what you see.
Old May 28, 2020 | 01:12 PM
bumblebee.4G69's Avatar
5 Year Member
Out of interest
Is there anyone near you who does exchange motors?
It maybe worth your while.to do an exchange motor it will save you a lot of work and get a replacement motor with a warranty.
Not sure if they have that kind of service in the USA , some countries do.
Old May 28, 2020 | 03:10 PM
DeeezNuuuts83's Avatar
This will decimate all after you put about fifteen grand in it or more. If we have to, overnight parts from Japan.
Old May 28, 2020 | 04:06 PM
LetsGetThisDone's Avatar
Intercooler piping an vac line not hooked up could make it not run. Thats a lot of unmetered air for a MAF based ECU.
Old May 29, 2020 | 08:13 AM
ak47m203's Avatar
Things like this will have lots of electrical gremlins. Goodluck.
Old May 29, 2020 | 12:36 PM
Matthew Blunk's Avatar
Hook everything up, intercooler pipes, maf, change the oil and get it to idle before you determine how bad the knock is. The motor might not even be getting up enough oil pressure in those 2 seconds it stays running. Especially if it's been sitting for a long period of time with low or no oil in it.
If it is knocking, your not going to make anything any worse by running it at idle for a min. The damage will have already been done. Just don't red line it or anything
Old May 31, 2020 | 12:22 AM
kernelh's Avatar
@razorlab
Not so good news, I cut open the oil filter and see copper and metal shavings. So seems to be a busted bearing. I will pull of the pan to see if can feel the busted bearing. Once confirmed I will be tearing down the block. I attached a picture for your viewing.
@bumblebee.4G69
Some places do offer that but havent found one near me yet. I was quoted 4k usd for a used block the other day
@DeeezNuuuts83
Im hoping so haha, So far no where near 15k not even close to a 3rd of that yet haha. Now me and the scientist have to rip apart the block and replace the piston rings the previous owner fried. Among other things
@letsgetthisdone
That what I was assuming, I just wanted to ask to be sure. but with the shavings I found from the oil filter I think I am going to start the engine removal.
@ak47m203
Valid point, but I have replaced the complete harness and no codes or errors have popped up since then aside from the brake light. Which is caused by the e brake being engaged.
@Matthew Blunk
I still may entertain that, but with the shavings from the oil filter might just get the rebuild started.
Below is the picture of the oil filter apart, Also the pan was completely cleaned out and dried before performing this task.
Old May 31, 2020 | 12:26 AM
5 Year Member
Mmm
Sadly from that photo it doesn't paint a very pretty picture.
Lets hope the damage isn't too bad
Old May 31, 2020 | 12:35 AM
kernelh's Avatar
@bumblebee.4G69
Agreed, but again at that price I paid for this I am really not bothered by it. I do have a lead on a 4b11t engine that may be cheaper then my last quote, ill be chasing that down tomorrow. I know this isnt for the faint of heart but I enjoy my hobby and will make it work. To be honest, it makes me wonder if the fire was intentional. Not pointing any fingers, but as people say the source of the fire was an odd place to start, and now to find out there was a rodnock. Just makes me wonder
Old May 31, 2020 | 12:40 AM
5 Year Member
I was wondering the same thing.
Seems odd that headlights would cause so much damage and so much heat.
I hope the new lead for the motor works out well for you
Old May 31, 2020 | 04:00 PM
kernelh's Avatar
@bumblebee.4G69
Thanks hopefully this motor comes through.
While I wait for a response can anyone chime in and give me a rough price of how much these engines run. I know it depends on mileage and if it has been rebuilt or what not. I have seen them between 3500-5000 usd, is that a good price?
Old May 31, 2020 | 04:13 PM
5 Year Member
If it helps I have seen Rallart motor going from wreckers for about $4000 AUD complete on a pallet ready to roll
Old May 31, 2020 | 09:38 PM
kernelh's Avatar
@bumblebee.4G69
Thanks for that information, Im assuming that is local to you?
