Sponsored by:
Sponsored by: CARiD
bulletproof racing double pumper install
Old Jul 22, 2020 | 02:01 PM
nor11384's Avatar
FCOTM Winner
Hey guys im writing this to ask you guys for my buddy who has an evo x. So the fuel hanger install is pretty straight forward. What i want to know is with the relay box thats included. One side of the relay box theres a harness that plugs into the fuel hanger. The other side has a red wire which should be power wire and a grey wire which i figure its ground. Now, how do you guys install this? I was told most guys just put the relay box under the seat and run the wires from there and a vaccuum line from the manifold to it. The battery in the evo x is in the back. The red power wire is not long enough to reach the battery from under the seat. I can always extend the wire but i dont want to do that. I was thinking maybe its supposed to go to fuse box but still not long enough. How have you guys installed this?
Old Jul 22, 2020 | 02:15 PM
LetsGetThisDone's Avatar
Just extend the wire.. Use a quality bare crimp butt connector, put heat shrink over, done. It comes with out a connector on the end for a reason.
I wonder how this works. Seems like it's constant battery power to the pump.
Old Jul 22, 2020 | 02:27 PM
nor11384's Avatar
FCOTM Winner
Theres relays inside that box...Id like to also know how it works. Its sold as a plug and play unit. People love it. The quality is awesome. Its absolutely gorgeous.
Old Jul 23, 2020 | 05:18 AM
splattj's Avatar
I love the execution on this! No cutting the factory harness! Though, I do have to wonder why the ground is smaller than the power wire.
It looks like you feed the relay box with constant power and the factory harness is still used for fuel level, sensors, and to trigger the relay box for the main pump, with a pressure sensor to switch the second pump on as well.
You're going to want a fuse near where that red cable connects to the battery to be safe. The quality looks top-notch though! Please report back after you get it installed.
Old Jul 23, 2020 | 05:10 PM
CurseDSM's Avatar
I run one of these its pretty simple. My red wire did reach my battery I had to use a car audio type fitting on the post and hooked straight up to that. I did do under the drivers seat and grounded to the seat bolt. Now what you could have done is ask them for ecu control. This would have eliminated the boost line coming from the engine bay. But basically its power and ground and boost source. I am not sure about where you would go through the firewall on the x but the 8 you can go though towards the middle of the firewall there is a grommet there.
Old Jul 23, 2020 | 05:13 PM
CurseDSM's Avatar
it uses the stock wiring to run power to the pump like you would on the stock stuff. It then uses the plug they supply to get power to the secondary pump as needed through the relays. Basically all it uses is the signal wire from stock plug to let the pumps know when to turn on, then uses the boost to a hobbs type switch to make the second one work. Relay box is pretty simple one controls the first pump second one is activated by boost or ecu depending on what configuration you use.
Old Jul 23, 2020 | 05:15 PM
CurseDSM's Avatar
Your correct they told me I didn't need to fuse it but to just run it off the battery and go.
Old Sep 6, 2021 | 06:26 PM
evotein10's Avatar
did you have any issues with the hanger leaking fuel?
Old Sep 7, 2021 | 01:37 AM
CurseDSM's Avatar
No. If you swapped out the fittings in the hanger you need to use orb fittings with an o-ring on them. The only issue I had leaking was I broke a fitting on the inside going to my fuel filter. Other then that no reported leaks other then that.
Old Sep 7, 2021 | 02:35 AM
evotein10's Avatar
Pressure sensor
[QUOTE=cursedsm;11940778]No. If you swapped out the fittings in the hanger you need to use orb fittings with an o-ring on them. The only issue I had leaking was I broke a fitting on the inside going to my fuel filter. Other then that no reported leaks other then that.
[/QUOTE
Old Sep 7, 2021 | 02:59 PM
CurseDSM's Avatar
And to answer your question before you edited no, I don't run a pressure sensor being my Haltech controls both pumps. I had Bp wire it that way being I don't trust hobb switch kinda deals. He just ran a bulkead fitting with a secondary wire out of that hole instead of the pressure switch.
Old Sep 7, 2021 | 08:36 PM
evotein10's Avatar
haha ty for that I was going to ask you about that but decided to delete. Are you located in Vegas? How did have bp do the wiring? I’m running a nrg ops flex fuel kit along with it that’s the reason why I was looking at options for that pressure sensor. I am planning on getting haltech or motec in the near future so that’s not in the plans at the moment.
Old Sep 8, 2021 | 01:29 AM
CurseDSM's Avatar
No I am in Michigan. I just emailed BP and asked if they could wire the pumps up so I can have my Haltech control both pumps instead of the pressure switch. Being I already ordered my pump I sent it back to them and they rewired it for me and sent it back then I followed the directions he gave me and selected an out put for the wire they added to the Haltech and done.
Old Sep 8, 2021 | 07:50 AM
evotein10's Avatar
ty so much brotha very good infos I appreciate it.
Old Sep 8, 2021 | 03:31 PM
CurseDSM's Avatar
Glad I could help. Thats what we are all here for right? To help everyone of us have bad *** cars lol.
WWkevoX
Evo X How Tos / Installations
12
Mar 22, 2013 08:19 PM
monkey_187
10
Sep 22, 2009 03:34 PM
EvolNinja
Apr 20, 2008 08:31 PM
Drive02Lancer
17
Mar 18, 2004 05:09 AM
