Sponsored by:
Sponsored by: CARiD
New to the Forum | New 2014 MR owner
Old Dec 25, 2020 | 12:57 PM
devoyl's Avatar
5 Year Member
Hi, thank you for reading my post! I've succeeded at getting my 4 door turbo dad car.
I just recently purchased a 2014 MR w/ 45k miles
The interior is flawless with some touring packages, the only bad I could really see is that it's got a bit curb thrash.
I think that I understand the importance of maintaining the SST transmission, but was hoping some could give me an idea of things I should change here soon. My goals are mainly bolt ons, UICP, cobb accessory and intake.
I don't have service records besides the carfax, but this doesn't tell much. I found some fluid on maperformance as well as the filter.
I read in the past that a certain filter should be relocated, but can't find out which one.
Merry Christmas!
Old Dec 25, 2020 | 04:49 PM
JimGVT's Avatar
Welcome! I also have a 2014 MR. Not aware of any filter to be relocated. If you live in area that uses salt, relocating AYC pump is recommended if you drive in winter. Enjoy the car!
Old Dec 25, 2020 | 04:51 PM
JimGVT's Avatar
I was advised to go opensource instead of accessport for tuning the MR because they have more control of transmission related parameters. I've been happy with that choice.
Old Dec 25, 2020 | 04:58 PM
devoyl's Avatar
5 Year Member
Oh ok, that's makes more sense. No snow here.
Thank you, I'll have to look into open source.
Old Dec 26, 2020 | 05:22 PM
JimGVT's Avatar
I think ECUFlash is the most common (what my car was tuned with). Tactrix cable and laptop is all that is needed to load map. Even that isn't required if you go to the tuner in person.
Old Dec 28, 2020 | 03:57 PM
GotKT?'s Avatar
Unless you are going to the track, not much is needed. However, a fluid change and filter cleaning or replacement might be wise. Before doing allot of bolt ons you might want to browse the Bay Area Evo group on Facebook. Allot of CA evo owners are having problems with getting their cars smogged. Seems that the state is cracking down on modifications.
Old Dec 28, 2020 | 04:03 PM
devoyl's Avatar
5 Year Member
yeah i've known in the past how bad aftermarket is in CA. Been really trying to get CARB legal stuff and hope they dont cry about it.
Old Dec 28, 2020 | 07:40 PM
ugakirk's Avatar
The SST is the biggest thing I would worry about with an MR. But it seems that guys that do SST a fluid changes very regularly, like 10-15k miles don’t have many problems.
ugakirk's Avatar
Congrats on the purchase and welcome
Old Dec 29, 2020 | 02:22 AM
Amworkom's Avatar
Congrats on your new car and Welcome aboard.
Old Dec 31, 2020 | 06:41 PM
deylag's Avatar
Congrats on the purchase! It's plenty capable with bolt-ons and a proper tune. Also if you haven't read this post I highly recommend keeping a copy with you :
Originally Posted by Kozmic Motorsports
Here are some points for driving and maintaining an SST equipped vehicle.
-When possible idle car in neutral. Examples: long lights, drive-thrus, traffic jams, long stops, etc.
(Reduces clutch wear by reducing pressure when idling).
-Do not launch car when transmission temperature is below 70C.
(Launching places extreme loading on the clutches and when transmission is not up to ideal operating temperature it will cause slip and more wear).
-Do not WOT the car if transmission below 60C.
(Same logic as launching a cold transmission).
-Do not over cool transmission. *A sump and aftermarket cooler while maintaining the OEM SST thermostat is the best option.*
(Over cooling can reduce ideal operating temperature causing clutch wear. The clutch pack operates within an ideal operating temperature range. The OEM SST thermostat for the cooler is set at 75C).
-Let the SST cool down when necessary. (Do not just shut the car down).
If the car has been driven hard for a long period of time (ex: road course racing), the SST temp will be high, as will oil and coolant temps. Some normal driving to keep fluid moving through the cooler with airflow will bring temps down safely.
-Do not WOT in Normal or Sport.
(Normal and Sport mode allow more slip than S-sport and will cause wear on the clutches).
-Allow transmission to warm up in Normal or Sport mode.
(The slip from Normal and Sport mode will allow the SST to warm up faster and will have less 'shock' on the drive train with cold fluid).
-Do not run aftermarket fluid.
(Aftermarket fluid has been shown to cause the clutch pack to wear prematurely).
-Change the fluid and filter at 10k miles if car is tracked and 20k miles service intervals if car is a daily driver.
(Replacing the fluid is cheap insurance against having any severe clutch or transmission damage. We do recommend doing the transfer case and rear differential fluid at the same time).
-Occasionally perform a teach-in.
(This will put the SST through a relearn procedure. This will help reduce potential slip and help the SST last longer).
-If engine exceeds OEM torque, adjust ECU so TCU knows.
(Adjustments must be made so the TCU is aware that the transmission is making more torque than stock, otherwise it will slip the clutches too much during shifts.)
-Intake changes (beyond a drop-in filter) require a tune.
(The SST relies heavily on the MAF to calculate torque. By changing the intake the MAF reads different than the MAF scales, which can affect the SST).
-Do not let off the throttle between shifts.
(The SST uses lots of information to determine what it should be doing. When accelerating, the SST has the upshift gear selected and vise versa for decelerating. Lifting of the throttle also decreases clutch pressure. So by letting off the throttle during the shift, the SST will get confused. This can cause a delayed shift and slip).
-Do not tow anything.
(This is beyond the design of the SST).
-Consider using Normal for freeway cruise.
(SST Normal mode, the SST will just leave inactive odd gear train in neutral to save fuel and reduce noise. Even if you go on-off-on-off with the acc pedal, the inactive gear stays in neutral. Compared to cruising in 6th gear (Manual) S-Sport, SST will toggle the inactive gear between neutral and 5th every time you apply-lift the accelerator).
-Driving in S-Sport will save your clutches, do not drive in Normal as often as possible.
(S-sport has 20% more clutch pressure than Sport mode, even more than Normal mode. This reduces slip, heat, and wear).
KidRyanPz
Jun 13, 2019 09:54 AM
Newevo1918
Canadian Forum
Jun 23, 2016 08:13 PM
mrwickd123
Aug 29, 2013 05:51 PM
