Sponsored by:
Sponsored by: CARiD
I'm Able To Move My Traction Control Button?!
Old Jan 11, 2022 | 08:29 AM
HoodieWeather's Avatar
5 Year Member
Hey Yal,
I'm in the process of taking trim pieces off my car and putting some felt on them to muffle.
I just took the panel off where the traction control is and within the harness, there are two plugs that are plugged into the button, and into a dummy button. Does anyone know that the harness comes with two plugs or just one? I don't understand why there was one plugged into the dummy switch.
What I want to do is move the switch to the far left. I managed to move the AYC button on the center console to the far left which looks better to me.
One plug was plugged into the far left.
Old Jan 11, 2022 | 10:00 AM
Biggiesacks's Avatar
Originally Posted by HoodieWeather
Hey Yal,
The blank on the left would be for an HID headlight leveling dial. I'm guessing you don't have HID headlights. I imagine your car has the pigtail so that mitsu didn't have to produce multiple wiring harnesses, and it's plugged into the blank keep it from swinging around and contributing to NVH. You can move them around if you like, shouldn't be an issue as long as you aren't putting excess tension on the harness.
Old Jan 11, 2022 | 10:14 AM
5 Year Member
Thank You Ever So Much.
I gave up. them switches are a ***** to figure out. So, weird they included that second plug when my car never came with HIDS. I got the car used as well. Honestly how can I tell if I did have HIDS?
Here's my order sheet.
Old Jan 11, 2022 | 10:43 AM
RazorLab's Avatar
States halogen lights in that sheet. You do not have hids.
The wire is there for the reason Biggiesacks mentioned. Reusing harnesses across trims
Old Jan 11, 2022 | 12:37 PM
5 Year Member
My bad, and thank you. If it's not to hard to get HIDS installed, mine as well do that down the road.
Old Jan 11, 2022 | 12:41 PM
5 Year Member
What's the easiest way to take those buttons out? They are suck in there rather TIGHT
Old Jan 11, 2022 | 04:33 PM
six40's Avatar
you need the OEM HID projector lights, the level switch which is plug & play, as well as the proper ETACS coding to allow them to work without flickering and destroying. Finding somebody to do that is the trickiest part unless you go to the dealer.
Old Jan 11, 2022 | 05:23 PM
5 Year Member
And we all know the horror stories of the STEALERSHIP!
THANKS
Old Jan 12, 2022 | 07:23 AM
RobbieOh's Avatar
5 Year Member
There is an etacs decoder fb group that has the etacs decoder software and discussions. I've downloaded it and set it up but have yet to do anything with it. Plan is to disable the TPMS..
Old Jan 12, 2022 | 08:31 AM
5 Year Member
https://www.facebook.com/groups/749048315134267
Old Jan 13, 2022 | 11:12 AM
RobbieOh's Avatar
5 Year Member
That would be it!
Old Feb 25, 2024 | 05:45 AM
dhruve661's Avatar
I have designed looms for IndyCar, IMSA, LeMans. Highly recommended building a mock-up with rope, string, tape and foam boxes. It will help you appropriately locate boxes, transitions (branches), connector orientation, (boxes need to be removeable), determine potential wear points, and vulnerability in case of a crash (maybe not an FSAE concern). When you measure for lengths add 5-10% or so (maybe others will comment). I even just did a mock up with my gokart project.
Now building a loom is a different topic, doing it properly pro-level is a skill...but for FSAE not required so don't stress, just make it clean simple and above all reliable. I would recommend seeking advice from the motorsport wiring alliance group on facebook which is full of pro-level loom builders
​​​​​​9apps apk
Old Apr 6, 2024 | 08:49 AM
AshleyCovingto's Avatar
LeXcite
Jan 17, 2022 08:05 PM
chrisff521
Jan 17, 2012 03:45 PM
EvoooB
Jan 27, 2011 09:25 AM
A.J.'s_EVO
Evo X How Tos / Installations
Feb 8, 2009 11:13 PM
MR Dan
Feb 23, 2008 12:24 AM
