Trunk spolier, non SSS
Its a 10 millimeter bolt on the inside of the trunk and a 10 millimeter nut tightened on to the stud of the wing on each side of the trunk. There's quite a bit of double sided tape that sticks on to the trunk. You have to becareful when pulling it off as to not bending the trunk out of shape. If you use something flat and thin to get in between the tape and the trunk, you have to becareful not to damage the paint as this area will likely rust.
08Lancer89 - Perhaps the wing that you already have on your GTS, but not the SSS package wing from the Evo X.
getoesouljah - Have your parts department look up part number 6515A111WB.
Don't take my word for it. Ask Mitsubishiparts.net...
http://www.mitsubishiparts.net/cart/?pn=6515A111WB
i took mine off immediately here are some pics with a rubber lip spoiler, then later on i ended up installing the deck lip spoiler
https://www.evolutionm.net/forums/sh...d.php?t=348874
flipflop
Mar 25, 2011 08:56 PM
