Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Play dvds while driving
Old May 11, 2008 | 11:14 AM
This_Guy777's Avatar
There has to be a way to get the multi-communication system to allow dvds to be played while driving. I understand why the laws say monitors cant be where the driver can see the screen while driving. Great. I dont want some dumb@ss crashing into me cause they were busy watching a movie while driving. I would like my passenger(s) to be able to do so. Of course there is not even an option in the menu of the multi-com system to change the disabled video of a dvd while driving. Could there be another way. Pointless to have dvd playing capabilities if my passenger cant enjoy a good flick while on a road trip.
Old May 11, 2008 | 01:06 PM
Mountainbiker54's Avatar
take a look at this thread.... https://www.evolutionm.net/forums/sh...d.php?t=335770
Old May 11, 2008 | 01:54 PM
Thanks Mountainbiker54. I read through the thread and it looks like they hit a dead end trying to get it to work properly. Before I even posted this I figured there would be a problem trying to get a movie playing while driving since the dvd and nav are both in one unit. It seems there would need to be a way to change the programming on the software installed in the unit. sux
Old May 12, 2008 | 11:05 AM
robh's Avatar
i fixed mine and it works fine i just cut and spliced in a switch on the green and red wire
on the gps antena i cut very carefully move the braided sheilding to the side as not to break it cut and spliced a switch from the core wire and can play movies all day
only down fall is you cant use navi while watching dvds but if you want to use navi just flip both switchs and it takes about 30 sec and navi works fine
Old May 12, 2008 | 12:30 PM
jackygor's Avatar
and you haven't written a DIY yet?!
Old May 13, 2008 | 11:09 PM
robh's Avatar
let me catch up my work ill try to sit down and write up a DIY tomarrow some time
Old May 14, 2008 | 12:48 AM
PDXEvo's Avatar
Has anyone enabled the remote screens on the Navi and seen if those turn off when you are driving?
Old May 17, 2008 | 07:33 PM
08MitsubishiGTS's Avatar
This is supposed to be the solution...http://www.tvandnav.com/index.asp?Pa...MMP=1013792389
Old May 18, 2008 | 09:49 AM
junction's Avatar
Nice find but for $800 they can keep it as far as Im concerned.
Old May 18, 2008 | 01:04 PM
boy36's Avatar
http://cgi.ebay.com/ebaymotors/Lance...spagenameZWDVW
Old May 19, 2008 | 10:24 PM
yea $800 is too pricey. And I don't know about that one you found...might be a good find but until someone tests it out i am not buying it...it only says detailed instructions anyway and doesnt mention including anything to bypass it. Kinda makes it sound like you can program it through the settings but I would think someone would of figured that out awhile ago. Hopefully whatever it is works if anyone tests it out please inform.
Old May 20, 2008 | 07:21 AM
robh's Avatar
i bouhg the one on ebay all it was is a picture of the green and red wire to cut and put a switch in line
it dosent work
if you want to be able to do this you have to wire 2 switches inline
one to disable the speed sensor the other to disable the gps signal
its not hard to do and only took me about 15 min
im sorry i havent had time to sit down and do a DIY on it yet
like i said its not hard to do ill see if i can round up a pic
ok cut and splice a switch in this wire do the same on the gps anntana
with the gps all you have to do is make a slit in the side push back the sheilding cut the core wire solder in a switch and put your car back to gether and your done
turn both switchs off to watch movie turn both switchs on to use navi
Old May 20, 2008 | 07:58 AM
robbie2883's Avatar
there IS another way to do this, but it involves pullign the unit apart and flashing the HDD. but it does unlock th eunit so you can put a larger hdd in it as well. the site with instructions is down right now, but when it comes back up i will post up the link.
Old May 20, 2008 | 09:35 PM
typoist's Avatar
ya i did the the cut 2 wires thing but i only installed 1 switch. Its a single pull double throw switch. Essentially you can run 2 separate wires trough 1 switch.
Old May 21, 2008 | 01:04 AM
wa2evo's Avatar
i am technically handicapped, please post step by step diy. thanks and good job!!!
