Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Vaccum level for EVO X???
Old Feb 10, 2012 | 08:46 AM
  #31
TheBlade's Avatar
Originally Posted by jrok1313
My Cobb Ap reads -8 or -9. I guess I have a vacuum leak somewhere.
-8 or -9 is normal, being read in PSI
-17 to -20 is normal being read as mmHg
Old Apr 4, 2012 | 06:52 PM
  #32
TEMPELIS's Avatar
sorry to start this thread up again but my torque pro app says im doing about -12 psi. ive noticed that when i first put the app on it was -9 to -10, now its almost -13 psi. does this mean anything if its that low? it goes to about -12 psi when i shift i think. then at WOT at around 4500-5000 rpms it goes to like 23 psi. im completely stock , just recently installed an ets intake and numbers havent really changed
edit: on the vacuum setting to mmhg it reads up -27.. is that too high, can it be a problem?
Old Apr 13, 2012 | 12:51 PM
  #33
desiromeo812's Avatar
I get about -18 r -19 on my stock X... Usually when you put a catback/TP/cams it will bring it down to -14 ish.
Old Jul 29, 2012 | 01:57 PM
  #34
S2K2EVO's Avatar
To add to the thread. I have a cobb AP with my mods listed in my sig. I am at -9 to -10psi at idle and when driving in between shifts the vacuum is around -11 to -12psi.
Old Apr 26, 2013 | 01:12 AM
  #35
nonschlont's Avatar
Had to bring this 1 back to life...
So had an aem digi boost guage installed recently and guage is reading -28 vacuum.. trying to figure out why its not at -22 ish, like on my previous 9.
Im at sea level...
TIA
Old Apr 26, 2013 | 09:28 AM
  #36
TheBlade's Avatar
Originally Posted by Clipse3GT
COBB reads in PSI not in mmHG like a boost gauge usually does...
Yep and -7 <> (-9) sounds like the perfect normal range if being measured in psi (of course this if from memory without doing the conversion math, but I'm confident with this as my final answer)
Old Apr 26, 2013 | 09:36 AM
  #37
TheBlade's Avatar
Im at sea level...
TIA
That's a lot of vac pressure. Was there a calibration process you had to follow? (I didn't think AEM required it, but might want to look into it).
Or check for any sort of squeeze point that might increasing the pressure from. Like some sort of Bernoulli's principle showing up from going from some huge vac source and being squished to the smallest inner-diameter tubing imaginable. But, although physics supports this...I would still think calibration or broken gauge IMO.
Old Apr 26, 2013 | 12:28 PM
  #38
nonschlont's Avatar
no calibration process. Checked all of the lines, no kinks, etc...
might just pick up a new prosport guage, never really liked the aem...
I did notice that on my set up, the "T" is right off the BOV, connected to the hardline goin to the int mani, rather than "T'ed" off right at the int mani.
evodziobak
Jan 26, 2016 04:24 AM
wibblersnatch
94
Jul 13, 2013 07:33 PM
djdino
Mar 11, 2011 09:15 PM
robyn402
Sep 12, 2010 11:43 PM
john blaze
Apr 13, 2010 07:40 PM
