Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Help with MBC install
Old Oct 6, 2009 | 02:07 PM
cnj4ever's Avatar
Ok i installed my Buschur Racing MBC the other day and i must not have put it in right bc it wont boost more than 13-15 psi all the way in. I installed the "T" fitting on the compressor inlet and hooked up the wastegate line into the bottom. Now my only question is when i started i noticed that the line on the wastegate is already T'ed, so now I am confused and second guessing my install. Any help would be nice especially if it has some Pics accompaning them. I have searched the HOW-TO and havent really been able to find a helpful write up. Not knocking anyones Write ups but i havent been able to find one that helps me. Thanks again
Old Oct 7, 2009 | 02:45 PM
cnj4ever's Avatar
bump for help please
Old Oct 7, 2009 | 04:20 PM
hotdog's Avatar
They're typically incredibly helpful at Buschur; have you tried sending them an email with some pictures, describing your problem?
I've yet to install an MBC in my X, otherwise I'd have a hint. I'd call/email them, though.
Old Oct 7, 2009 | 04:21 PM
ScottSpeed21's Avatar
You don't need to use the T fitting on anything. The Buscur MBC has an arrow on it right, showing the direction of flow? You run a hose from the nipple on the compressor outlet pipe to the inlet on the MBC, and then a hose from the outlet on the MBC to the wastegate actuator nipple. Pretty simple.
Old Oct 26, 2009 | 04:06 PM
kautiongsr's Avatar
yup thats how i did it.. works great.. i have an mr if that matters..
Old Oct 27, 2009 | 11:56 AM
cnj4ever's Avatar
ok if you cut the Stock EBC out of the loop is it throwing a code then??
sleeper04
May 23, 2011 12:27 PM
Aux.
40
Aug 23, 2008 07:22 AM
AfireINSIDE
Apr 6, 2006 05:34 AM
Aux.
Dec 21, 2005 08:45 AM
spinall4
10
Mar 29, 2004 10:01 PM
