Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HKS Turbo Type 1 Speed wire
Old Mar 5, 2010 | 11:10 AM
evoxz's Avatar
Originally Posted by andrealltrac
Sorry for the late reply but I guest better late then never.
First time I have triyd this it did not work also, after a month I found the RPM wire and I got my avic-d3 nav system so I gave it a second try. This time I made shure I hade a good connection and it work, now there is 3 possibility
1: the good connection was all it needed
2: the nav created a load on the vss circuit and pull more amperage witch in turn created a stronger signal
3: if the factory does not make use of the vss it may be open circuit
Are you shure the connection is a good one and what kind of head unit are you using?
Anyone with this working could you post what head unit you got?
I tested the connection from the molex connector to the turbo timer circuit board and it was a solid connection. Maybe your right about the nav pulling more amps. I have the stock radio. I wonder if I install an aftermarket nav if it will trigger a stronger vss signal? Did you have the factort nav installed initially or the stock radio like me?
Old Mar 6, 2010 | 04:22 PM
andrealltrac's Avatar
I had the non- rockford fosgate radio
How did you connect to the white and blue stripe wire?
Old Mar 7, 2010 | 07:25 AM
evoxz's Avatar
With the red Wire connectors that come with the hks kit. The tap onto the main wire and allow a lead off of it! I have the fosgate radio.
Old Mar 7, 2010 | 10:33 AM
It would be nice if someone could confirm that they got the signal from the vehicule speed sensor working on there hks tubo timer type1 with the stock non-nav unit.
Anyone?
What kind of head unit you got with the turbo timer?
Old Mar 7, 2010 | 03:07 PM
evoxz's Avatar
Anyone?
Yes this would help me any any future people who want to install! Any feedback out there?
Old Mar 7, 2010 | 08:15 PM
Sir Kyle's Avatar
I hooked up the type 1 on a base GSR. I got a signal from the white w/ blue stripe. Just need to calibrate it.
Not sure if that is what you were asking for..."stock non-nav unit"
Old Mar 8, 2010 | 10:24 AM
evoxz's Avatar
Yes, thank you at least at least I know in some cases it's possible!
Old Mar 9, 2010 | 09:53 AM
Evoxz your connector that came with the type-1 might be f%$k or something ???
Old Mar 11, 2010 | 05:06 AM
evoxz's Avatar
I testes all connections and even placed the hks blue wire into the molex connector with no luck. I will look at everything again this weekend. Like I said before when I tested the A/C signal it was very minimal (less than a volt). Did anyone out there use or know of which wire behind the gauges provides a vss for the speado?
silver05evo8
Feb 21, 2017 01:47 PM
MharAndal
Sep 8, 2013 09:01 AM
cky3396
124
Jul 6, 2012 04:02 PM
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
kingsolomon12
Apr 28, 2007 02:45 PM
