Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
help with headlight painting
Old Mar 15, 2010 | 11:48 AM
EvoXTX's Avatar
ive seen the few other threads about painting the lights..ive put the oven to 200degrees..for about a minute and a half to heat the light up. pulled it out..and it doesnt budge. whats the best way to get the housing off? tips or tricks? i have a flathead screwdriver im using to try and pry it but i dont want to crack the plastic or damage it at all. please help!
Old Mar 15, 2010 | 11:56 AM
bluegsr's Avatar
200 degrees for 25 minutes haha
Old Mar 15, 2010 | 11:58 AM
EvoXTX's Avatar
umm..i want to still use these afterwards.
Old Mar 15, 2010 | 12:01 PM
whitegalant's Avatar
Its gonna take more then a minute and a half, when I did mine I let the oven heat up to 200 then put the headlight in, then turn the oven off and let them sit in there for about 10 mins.
Old Mar 15, 2010 | 12:04 PM
EvoXTX's Avatar
should it be fairly easy to seperate or will some prying still be needed?
Old Mar 15, 2010 | 12:18 PM
evolvedx's Avatar
23-25 min @ 200F. 200 is not that hot. I did mine for 25 minutes each. Don't let them sit, just deal with them being a bit warm to handle. They're pretty easy to pull apart, just make sure the clips are all free. Don't forget to pop the metal clip off the top and take the 4 screws out BEFORE you put them in the oven.
Old Mar 15, 2010 | 12:30 PM
EvoXTX's Avatar
yep i did it for about 15-20 minutes and it worked fine. thanks guys!
Old Mar 16, 2010 | 04:48 AM
prodigy1210's Avatar
Lets see pics when this is done k.. Best of luck
Old Mar 16, 2010 | 09:23 AM
EvoXTX's Avatar
posted some pics in my progress thread
https://www.evolutionm.net/forums/ev...ys-thread.html
Old Mar 19, 2010 | 09:58 AM
Poik242's Avatar
Looks like they turned out pretty good, I really want to do this now to mine.
Old Mar 30, 2010 | 02:25 PM
sandman121383's Avatar
looks like they came out great man! maybe one weekend ill feel ambitious and do mine!
Old Apr 27, 2010 | 11:26 AM
fattytoofat's Avatar
does any condensation occur cause the headlights were taken apart and painted?
Old Apr 27, 2010 | 11:37 AM
xPRimNT's Avatar
^ If you don't seal it up properly. It's usually not an issue.
Old Apr 27, 2010 | 11:57 AM
ugakirk's Avatar
Looks good. I'm gonna try this prolly next weekend.
Old May 1, 2010 | 06:29 PM
wrxnevox's Avatar
i did heat mine for 15 minutes at 200 degrees
EndlessRed
May 22, 2013 09:00 PM
wewtRallywewt
Sep 11, 2012 08:31 PM
Betty
27
Feb 10, 2009 03:41 PM
mscc04
Jun 27, 2006 04:25 PM
feldguy
May 11, 2006 03:34 PM
