Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
LC1 Controller location
Old Dec 8, 2010 | 08:41 PM
initial_d2k's Avatar
I'm about to install the Innovate LC1 WB. I know a lot of ppl recommend putting the O2 sensor on the left (9 o'clock position - when looking from driver's perspective) of the Downpipe.
But from looking at the length of the O2 sensor wire, it seems like i will need to stuck the LC1 controller under my car.
What would be a better place to weld the O2 bung or pass the wire if I want to keep the controller inside my car?
This is mainly a precaution against future lowering and massive snow storm in Montreal
Thanks!
Old Dec 9, 2010 | 03:50 AM
MicMcKee's Avatar
I mounted my controller under my glove-box and ran the cables through the grommet above it into the engine bay...
The from there I ran the wires behind my center console and mounted the display to the left of the dash...
Old Dec 9, 2010 | 07:04 AM
That one way im thinking of doing.
That would also need a bung at 3Oclock position right? or some what around there
Old Dec 9, 2010 | 07:24 AM
MicMcKee's Avatar
Correct,
I had a lot of slack left over from mounting it on my DP and running the cable that way
Old Dec 20, 2010 | 02:24 AM
solipsism's Avatar
I mounted mine at the 3 o' Clock postition as well. I mounted the controller under the passenger kick panel on the left hand side (part of the console past the shifter where if the passenger kicked his left foot to the left he would hit).
Like the above posters I also ran the cable through the grommet on the passenger side of the firewall and had more then enough cable that I was worried I wasn't going to be able to fit the controller and the cable in the panel, but I did.
Old Jan 5, 2011 | 07:43 AM
fknchristoph's Avatar
I ran mine through the hole in the passanger floorboard and had just enough room to reach the 9 oclock. but in lc-1 doesnt work. jumps from 8.5-22.4, then flashes and jumps around. wired wrong? calibrated wrong? i'll post pics later
Old Jan 5, 2011 | 07:12 PM
scheides's Avatar
EvoM Moderator
I ran mine through the hole under the passenger seat and used the rear o2 sensor bung as well as its hole into the cabin. THen mount the controller under the seat, run wires under the center console, and you're golden
michiganevox
Mar 5, 2011 07:25 PM
veszett
Apr 10, 2010 04:54 AM
gosu.pianist
Feb 21, 2008 06:16 PM
Inprogress
Nov 8, 2007 09:40 PM
SwiftEVO
10
Jun 7, 2007 04:47 PM
