Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
AEM DIgital boost gauge
Old Apr 8, 2011 | 12:46 PM
ericmevo's Avatar
Need help installing the boost gauge please.
https://www.evolutionm.net/forums/ev...lean-hell.html
https://www.evolutionm.net/forums/ev...c-install.html
with the these two links, whats the best option? I dont get to understand the first link anyhow.
THanx guys
Eric
Old Apr 8, 2011 | 02:30 PM
OZ_2435's Avatar
I have this gauge. Not sure what problems you have, everything?
Only problem I had was the actual wiring, which I figured out from a few different threads.
You only need the red and black wires. Red wire into the cig/acc fuse and the black to the ground (bolt in front of the fuses).
Old Apr 9, 2011 | 05:23 PM
ericmevo's Avatar
But its two ways
True way u said about the red & the black. But the place u put the T in are to ways. thats where im lost
Old Apr 10, 2011 | 09:02 AM
OZ_2435's Avatar
If you aren't using a mbc do this, which is what I did. Works perfectly.
Old Apr 10, 2011 | 09:13 AM
fknchristoph's Avatar
or you can T it off where the vacuum hose comes off the back of the bov
Old Apr 11, 2011 | 09:58 AM
ericmevo's Avatar
Thats what i did.
I did whats on the picture. But the reading is worng. Thats why im wondering. I have the access port and if the gauge says 0 the access port says +5
Old Apr 11, 2011 | 10:08 AM
faulty gauge then.. send it back to AEM. great customer service.
its not a hard install.. red is power, black is ground. plug and play.
Old Apr 17, 2011 | 05:32 PM
HPEVOX's Avatar
I have my T'd in the locations just as in the picture and wired in the fuse box in the fashion stated above. AP reads vacuum differently than the AEM gauge, but boost is identical on the boost side of the spectrum.. What problems are you having?
glamcem
Feb 14, 2012 09:07 PM
chaotichoax
Jan 30, 2010 06:46 PM
Skym
16
Jan 26, 2010 11:13 AM
criptballer
Nov 29, 2009 11:02 AM
Tractionlimit
Sep 10, 2009 08:59 AM
