Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Night Shade Removal?
Old Apr 14, 2011 | 10:46 AM
beetle_orange's Avatar
To those that have done so, how did you guys remove the tint on tail lights with night shade / tint.
just wanted to hear whether or not it can be done without damaging the clear plastic lense.
Old Apr 14, 2011 | 02:04 PM
07outty's Avatar
remove the "paint" with acetone and soft cloth.
if the acetone slightly clouds the lens surface....it can be brought back to clear
with fine polishing compound.
Old Apr 14, 2011 | 02:14 PM
awdturbo8's Avatar
Whatever you do. Do not use goof off. I ruined my tail lights on my SS trailblazer. It burnt the plastic and left them white.
Old Apr 14, 2011 | 02:41 PM
a friend is discouraging me in buying anything that has been sprayed on with "night shade" he painted his fender signal lights and couldnt remove them properly so he ended up just buying new ones. that is why he is telling me to stay away from these tail lights that were sprayed with night shade.
Old Jun 6, 2011 | 09:37 AM
bluepeartype-s's Avatar
Registered User
I used night shade this weekend and used my fiance' acetone in the cabinet to remove it...comes off easy. Night sahde should be ok to use on car if the person did not put more than 3 layers on tails.
-B
Old Jun 6, 2011 | 09:42 AM
mrg72433's Avatar
I would be careful with the acetone. Some acetones have chemicals that will eat the plastic of the lense. Tried high grit sanding and polishing to take it off
Old Jun 6, 2011 | 01:31 PM
total0wnage's Avatar
^this, use a strong rubbing alcohol
Old Jun 7, 2011 | 06:49 AM
Phantom09's Avatar
good luck with acetone!! id go with sanding and buffing! acetone eats plastic.
Old Jun 7, 2011 | 08:44 AM
Registered User
Everyone here is so quick to judge...yes acetone...then clean it off with water....yes if you use a crap load it will eat it off.. So far there have been no issues.
Thanks
Old Jun 7, 2011 | 09:40 AM
mrg72433's Avatar
Thanks
I was not being quick to judge if it came across that way I apologize. I was merely offering a caution about acetone and another allternative. No judgeing just a friendly warning.
Old Jun 7, 2011 | 09:58 AM
Registered User
no problem and thanks...I realize the conseqences of acetone.
Old Jun 7, 2011 | 10:34 AM
PHDoc19's Avatar
Acetone is the chemical that eats plastic. I would never use it on anything plastic that I would like to remain transparent. Didn't you guys ever hear about all those convertibles that had to have their rear plastic windows replaced because they suddenly went opaque, almost as if something happened overnight? Oh... maybe that just happened to my neighbors.
While I have not tried it, ethanol is probably a good solvent to use. Best quality, it won't etch your plastic tails.
Old Jun 7, 2011 | 02:30 PM
Indrid Cold's Avatar
I used brake fluid to remove my nightshades. Worked great and I had 5 layers sitting on there.
Tails look just like they did before I put the nightshades on too.
Snopro
44
Jan 23, 2013 11:51 AM
mshilto89
Lancer How Tos / Installations
16
Sep 26, 2011 12:06 AM
bluegsr
Nov 16, 2009 07:04 AM
rickay726
Aug 10, 2009 07:29 AM
absolute
Jul 2, 2009 01:11 AM
